post #1 of 15 (permalink) Old 16-08-2008, 04:50 Thread Starter
KV6 Timing Gear Tools
I've also posted this in technical but I need local, as in 'down under', advice.
I'm doing the head gasket on my 2002, 75 Classic 25.l V6 and my mechanic has asked about the options to do the timing set up with/without the special Rover tools.
Is it possible to do the timing setup without them? How?
Can they be bought/loaned/rented locally?
Can they be fabricated easily?
Are there pics of them?
Canary.
Canary is offline
post #2 of 15 (permalink) Old 19-08-2008, 20:14
Car: 2.5/ jeep patriot crd
our Rover club in Bris just bought a set so members can hire it out for workshops or themselves to do cambelts. You can do it without the locking tools, but even experts say it is unwise.
latest Car Mechanics magazine in the UK has step by step instructions and photos on how to do it....worth ordering over the net ...July August editions
miketata is offline
post #3 of 15 (permalink) Old 26-08-2008, 12:39
Being as the Landrover Freelander and Kia Carnival share the same 2.5 KV6 motor,wouldn't any of thier servicing depts have these same tools ?
genpk is offline
post #4 of 15 (permalink) Old 26-08-2008, 12:52
Car: calibra LE 4x4 turbo
as a MGR and NAC-MG tech i would strongly advise not to atemped this without the tools!
rich_gsi is offline
post #5 of 15 (permalink) Old 26-08-2008, 20:27 Thread Starter
VS1290 Timing Tolls Set
Thanks for your advice and suggestions.
As all the advice points to it being very difficult to attempt the timing set up without the tools, I have ordered the VS1290, Sealey tools set.
It will become available to hire out shortly for anyone who requires it.
Aside from the timing my only issue now, is to determine if a liner has sunk...seems there is little accurate information about liners.
Canary
Canary is offline
post #6 of 15 (permalink) Old 28-08-2008, 03:26 Thread Starter
Liners
We have measured the liner protrusion and found them all to be approximately 2 thou!
The timing tools are on their way so it's all go to finish the 'head job'
Canary
Canary is offline
post #7 of 15 (permalink) Old 28-08-2008, 06:26
Good news! It is not advisable if at all possible to replace the belts without the tools.
Not a cheap item though!
post #8 of 15 (permalink) Old 28-08-2008, 06:28
Picture of the AST Kit I have.....
post #9 of 15 (permalink) Old 28-08-2008, 12:15
I would take Daves advice as gospel as I think he has done a few of these before.
Unfortunately he dosn't do house calls to Australia!!!!
genpk is offline
post #10 of 15 (permalink) Old 02-09-2008, 03:13
Car: MG ZTT
Canary
5 - 5 thou with a max step between cylinders of 1 thou.
epson is offline
post #11 of 15 (permalink) Old 17-12-2010, 15:15
Car: Other Rover
NEED 2.5 KV6 Timing Tools
Is there anyway I could get this Kit shipped to the US? I have an 03 LR Freelander and need the kit to put the motor back together. Please help!
03Freelander is offline
post #12 of 15 (permalink) Old 17-12-2010, 17:02
I would but I need to use it within the next three weeks
post #13 of 15 (permalink) Old 17-12-2010, 18:12
If anyone knows the inlet valve opening at TDC or the peak lift angle you can set the cams with a dial gauge and degree plate in exactly the same way as setting vernier pulleys. Trouble is, I've never seen these figures published and I no longer have access to them.
You could set them up with the cams balanced about TDC and it would run OK, but I know this is not the production setting. I think the cams are about 3 degrees advanced from this setting.
You would still have to make up a few tools for holding camshafts and such like.
1955diesel is offline
post #14 of 15 (permalink) Old 06-01-2011, 22:26
Car: MG ZR+ 2.0TD (115) 2003
In terms of sunken liners, the tolerances accept 1-5 thou, but in reality, you really need 3 thou. One of my engines was put together with only 1 thou and it failed.
DrEvo is offline
post #15 of 15 (permalink) Old 08-01-2011, 11:28
Re the timing belts,as a matter of interest,a local mechanic who has done a few KV6 motors reckons the belts can be changed without the use of the specific locking tool as long as each belt is changed one at a time.
Not sure if its fact or fiction but looking at it logically,if at any one time at least two of the belts remain in place,I can't see how anything could go out of alignment
genpk is offline
2.5 KV6 Timing Belt Tools dearot Wanted 3 30-09-2009 11:07
Help! Timing Gear Tools... Canary MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 16-08-2008 19:35
T16 Timing Tools ravthechav Coupe 1 16-11-2007 05:57
m series timing tools and belt tensioner guage pasty muncher MG / Rover Related Chat - up to 2005 2 17-10-2005 20:01
KV6 camshaft locking tools. Richard Moss Rover 800 2 06-10-2005 09:28
