post #1 of 14 (permalink) Old 22-11-2008, 20:45 Thread Starter
smoking from cold
hi peeps i am new on here s i would like to say hello first before i start asking for techy help lol,
i have a 53 plate rover 25 diesel, on start up when cold it diesel smokes for about 200 yards up the road then clears and runs perfect all day , i though it might be a leaking injector so i got another 4 and its made no difference appart from it seem to be putting more fuel in than before, i plugged a snap on code reader on it and it came up with 2 faults
code p1218 needle motion sensor and p1402 undocumented code
please help and thanks in advance
cossiedave is offline
post #2 of 14 (permalink) Old 22-11-2008, 21:30
Car: 45 2.0 Diesel
Needle motion sensor? Think that might be the lift sensor on #1 injector, check it's plugged in and the wiring isn't chafed, tends to be a common problem.
What type of injectors did you put in? injectors out of a 25/45? or out of a 200/400/600? they are different, the earlier injectors will flow more fuel in a 25.
Chrisund123 is offline
post #3 of 14 (permalink) Old 22-11-2008, 21:46 Thread Starter
hi and thanks for the quick reply, the injectors i fitted were told they came out of a 45 but its goes a lot better and black smokes when on full throttle, is there any way to knock the fueling back a little
post #4 of 14 (permalink) Old 22-11-2008, 22:05
Car: 45 2.0 Diesel
Not without a remap I'm afriad! You can always try and increase the air going in a bit by increasing the boost pressure though, which can even things up.
post #5 of 14 (permalink) Old 23-11-2008, 19:19
Car: MG ZR+
when you say it diesel smokes. What colour. is it running on all for cylinders when cold. the needle lift fault probably as just come up coz uv changed the injectors.
T.Morris is offline
post #6 of 14 (permalink) Old 23-11-2008, 21:21 Thread Starter
its white/grey mate and it misses on a cylinder when you start it and then runs fine after a couple off revs , some one said it may have a bent conrod but it runs great as soon as it starts to warm up
post #7 of 14 (permalink) Old 23-11-2008, 22:38
Car: MG ZS+ TD135+
Your 45 injectors sound like they've seen better days, they should be exactly the same as 25 ones. If you've put the older SDi type injectors in though this would explain the power and the smoke.
If they are definitely 45 injectors, it could be that they're quite worn, so I would expect some smoke for a while on a cold engine.
It could be a glow plug issue that's causing the poor combustion on a cold start.
SDI_Tim is offline
post #8 of 14 (permalink) Old 24-11-2008, 17:57 Thread Starter
thanks for the replys and i will take it to work tomorrow and check wires nd lso check heater plugs
post #9 of 14 (permalink) Old 24-11-2008, 19:12
Car: MG ZR+
soz but it does sound like i bent rod to me to. av you or any1 bin through any water. best do a compression test.
they are the symptoms for a bent rod sorry to say.
T.Morris is offline
post #10 of 14 (permalink) Old 24-11-2008, 21:57
Car: MG ZS+ TD135+
Wouldn't a bent rod cause poor running for more than 200 yards, and maybe some roughness in the engine? I'm no engine mechanical expert, just curious.
SDI_Tim is offline
post #11 of 14 (permalink) Old 24-11-2008, 22:17 Thread Starter
if the rod has i slight twist in it i may be down on compression untill it warms up a little but i was hoping it was some thing eisier to fix
post #12 of 14 (permalink) Old 13-02-2016, 08:17
hello just read this post and i have the p1218 code on my car and you said look for a wire and theres a brown plug what has bin broken the car runs fine just a light on dash could u tell me there the wire goes or comes from so i can fix it or replace it thanks
freakstarfish is offline
post #13 of 14 (permalink) Old 13-02-2016, 08:24
hello just read this post when you said the P1218 can be a wire i have looked around my car and there's a brown plug what broken and the wire goes to injector 1 put where's does the other end go can it be repaired or fixed ?? thanks its a rover 45
post #14 of 14 (permalink) Old 21-02-2016, 22:09
Other end is on a metal bracket next to the injection pump for the injector wire to plug in to.
Smoking Graham E Diesel Forum! 10 14-06-2007 12:11
Smoking? Simon Widdop Others 10 20-11-2003 19:18
