post #1 of 14 (permalink) Old 01-08-2005, 23:23 Thread Starter
Gearbox oil info needed
I was thinking about changing the gearbox oil on my rover 200 (1.4 V-reg). It has the original oil in and I was wondering on what peoples views are on changing it?
It seems a bit of a pain to do unless you can get it on a ramp so I am thinking of letting my local mechanic do it for what he would charge for labour and I would just provide the oil.
Which gearbox oil do you recommend?
andywhitehurst is offline
post #2 of 14 (permalink) Old 02-08-2005, 06:21
Car: 2004 MG ZR 120+
cant comment on type of oil you should use..but changing it is pretty straight foreward...see here
misterreliable is offline
post #3 of 14 (permalink) Old 02-08-2005, 06:25
Make sure MTF94 oil is used, available from Land Rover or Rover dealers.
It's a fill-for-life oil, no need to change it really.
post #4 of 14 (permalink) Old 02-08-2005, 09:02
i think i used esso stuff and it did make it smoother... prob worth doing and not particularly difficult.
jonR200 is offline
post #5 of 14 (permalink) Old 02-08-2005, 09:42
MGJohn's Avatar
Yes, 'fill for life' oil in the gearbox from the factory.
However, it's a good idea to top up the level just in case there has been a slow progressive loss for some reason. Not a difficult job. I find a funnel with a short length of garden hose helps and avoids spillage. If it needs quite a lot to top up, then investigate the reasons for the loss.
After ten years of ownership, I drained the gearbox oil on my 1990 Montego (PG1 box) as I felt it must certainly need changing. That as before I learned about the 'fill for life' gearbox oil. I did that after 100,000 miles and the oil which came out of that gearbox then was as clean and clear as when it left the production line.
B>>M>>W ....
MGJohn is offline
post #6 of 14 (permalink) Old 02-08-2005, 11:03
Car: Rover 200 Coupe
Major Ingram Make sure MTF94 oil is used, available from Land Rover or Rover dealers.
Er dont mean to appear rude but no its not!
BV75W-80 is the correct oil for R65 box. Last part number i have for it was VYK000080 from a Rover dealer, 1 litre bottles from memory they take between 2-2.5litres from empty.
GONZO is offline
post #7 of 14 (permalink) Old 02-08-2005, 17:35
I thought the R-65 Gearbox took 1.75 litres from empty to full?
post #8 of 14 (permalink) Old 02-08-2005, 18:28 Thread Starter
So is it worth changing the gearbox oil or just topping it up?
post #9 of 14 (permalink) Old 02-08-2005, 18:48
TBH just check the level and top up
cjmillsnun is offline
post #10 of 14 (permalink) Old 03-08-2005, 14:54
Amount was a guestimate mate i knew it used ta come in 2.5 litre bottles and you usually got a bit a change out of one from dry.
Sorry probably should of said that above
GONZO is offline
post #11 of 14 (permalink) Old 03-08-2005, 16:46
Car: Silver Stormer ZR turbo.
Yes maybe, but isn't MTF94 the stuff MGR use in their boxes now and recommend. Better stuff I believe.
ashy is offline
post #12 of 14 (permalink) Old 03-08-2005, 18:29
MTF94 is what you need to use in a PG1 box. The R65 needs different oil BV75W-80.
post #13 of 14 (permalink) Old 03-08-2005, 19:02
Argh that be it matey.
GONZO is offline
post #14 of 14 (permalink) Old 13-09-2006, 12:33
Rover 25 Gearbox Oil Change
I'VE TRIED YOUR LINK PUT CANNOT ACCESS IT. COULD YOU TELL ME WERE THE NUTS ARE LOCATED THAT I HAVE TO REMOVE IN ORDER TO CARRY OUT THEAR GEARBOX OIL CHANGE
MR TT is offline
Gearbox oil - sealing washer part # needed! adchelle MGF and MGTF (Sponsored by MGFnTFBITZ) 1 11-11-2008 20:12
Gearbox seals info. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 8 16-08-2008 10:59
Auto Box Oil Change info needed A S A P please northstand MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 09-12-2007 09:44
gearbox info jasonc46 Rover 600 2 21-10-2006 07:45
PG1 Gearbox Info Dr Dave Others 9 20-01-2003 09:22
