post #1 of 5 (permalink) Old 27-11-2010, 20:30 Thread Starter
Immobiliser Fault??
Evening Gents.
I have a problem with starting my 25 Diesel.
Today I got a spare key cut (new fob to be ordered when I have the cash)
I went to test it and obviously it would start the engine because the old fob was in my pocket, I briefly held it near the key in order to start it and it started ok. Drove back from the shops no problem.
Later on when I went to start the car, I notice that the red immobiliser LED on the dash was not lit. Tried starting the car with no luck, all the lights come on, glow plugs warm up but it doesn't spin over.
When I tried to pull the ECU plug out then back in, the red LED light comes on and I can start the car. But next time I stop, it wont start again.
Any suggestions?
I am thinking I may have confused the car when I pulled the fob away from the steering wheel the first time...
Nick
Kehaar is offline
post #2 of 5 (permalink) Old 27-11-2010, 21:13
Car: NOW HAVE A 25, 45 & 75
Apart from locking and unlocking if you have remote locking and turning the immobiliser on and off the fob does not even have to be in the car for the car to run. Check the cars earth connections etc, connections on starter motor, etc.
LORDPSK is offline
post #3 of 5 (permalink) Old 28-11-2010, 12:04 Thread Starter
It looks more like the Immobiliser itself is at fault because the red LED on the dash doesn't light up except when I pull the ECU and re plug it in...
N
Kehaar is offline
post #4 of 5 (permalink) Old 28-11-2010, 15:47
Mmmm....Rover..
technozen's Avatar
Are you pulling the plug from the engine ECU or Alarm ECU?
technozen is offline
post #5 of 5 (permalink) Old 28-11-2010, 15:52
01379 669375
Car: Vauxhall ASTRA GTC VXR
Eka code
Hi
If You require the eka code for your vehicle we can get this via the chassis number and this over rides the immobiliser so the car will start.
MG-ROVER-CODES is offline
immobiliser fault big_fact_hunt MG ZS / Rover 45 & 400 12 08-02-2010 17:53
Alarm / Immobiliser Fault DOOD MG ZS / Rover 45 & 400 5 26-10-2009 15:19
strange immobiliser fault danmgzr105 MG ZR / Rover 25, 200 & Streetwise 8 20-03-2009 18:20
Rover 100 Immobiliser Fault Grizz Metro / Rover 100 2 11-01-2009 16:34
Electrical Fault - Immobiliser? SammyP MG ZR / Rover 25, 200 & Streetwise 2 17-10-2008 23:33
