post #1 of 11 (permalink) Old 11-10-2005, 11:45 Thread Starter
Rover 75 instrument cluster
Hello All,
Left turn indicator light in the instrument cluster no longer lights when turning left, all bulbs flash on outside of car. I thought it would be failed bulb. thanks to advice already given I removed instrument cluster. However, back of unit is held on by tamper proof screws with sticker saying that there are no owner servicable parts inside! Is there a bulb inside or is it an LED or something? Any advice would be appreciated.
Thanks Mike d7
miked7 is offline
post #2 of 11 (permalink) Old 11-10-2005, 12:28
Car: Rover 75 V8
The workshop manual does say that the unit has no serviceable parts
You can run a test on the instrument panel using the instructions in this link-test
The test will at least show if the panel bulb is working.
The workshop manual also says that if 'either direction indicator warning light fails to flash................indicates that one of the external direction indicator lights is not operational (bulb failure or system fault)'. Just in case this could be it check all of your main indicator bulbs again (not the side repeaters).
If all else fails I can only then suggest the 75 version of 'system restore' i.e disconnect your battery, leave for 30 minutes and reconnect. If it is a software glitch then doing so might sort it.
hth
Mike
MikeM is offline
post #3 of 11 (permalink) Old 11-10-2005, 12:47
Car: MG ZT 180 SE in XPG.
Certainly sounds like a bulb failure inside the unit tbh. if you can get the right security bit (maplins is normally good) you could always take a peek after trying mikes stuff.
MattL is offline
post #4 of 11 (permalink) Old 11-10-2005, 15:07 Thread Starter
Thank you MattL MikeM
Good advice as always. I will try removing and cleaning each exterior indicator bulb and if that does not work will swop right to left and see if fault changes. I suppose that it may come down to a wrong wattage bulb or even dodgy connection. if I have to delve into the instrument panel then I think it will be a job for auto electrician as I think that the light inside will be LED rather than bulb.
Thank you both
Mike D7
miked7 is offline
post #5 of 11 (permalink) Old 11-10-2005, 19:17
Car: Rover 75 V8
Originally Posted by mjt
You could always try the instrument pack self-diagnosis. Function 2.0 tests all the warning lamps and drives the gauges to full-scale and back. If the LH indicator warning fails this test it will definitely localise the fault to the instrument pack.
Originally Posted by MikeM
You can run a test on the instrument panel using the instructions in this link-test The test will at least show if the panel bulb is working.
see above ............................
MikeM is offline
post #6 of 11 (permalink) Old 11-10-2005, 19:24
mjt
Car: '99 75 Club SE 2L V6
Oops!
mjt is offline
post #7 of 11 (permalink) Old 12-10-2005, 13:07 Thread Starter
Run test and problem is in instument cluster
Just to tell you that I have run diagnostic test and the instrument light is U/S. So I will either have to bite the bullet and get an auto electrician involved, or try to take the back off and look inside the instrument cluster to see if the bulb is replacable or if it is an LED. Any one know what is in the instrument cluster?
Thanks all Mike D7
miked7 is offline
post #8 of 11 (permalink) Old 12-10-2005, 14:03
Circuit boards mainly i guess. I would say its at least got to be worth a look yourself as long as you can get it open.
MattL is offline
post #9 of 11 (permalink) Old 12-10-2005, 15:42
Car: Rover 75 V8
There are always new and second hand instrument packs coming up on ebay and it might pay to pick one up just to get the bulb or something. Here's one on now:
ebay
Regards
Mike
MikeM is offline
post #10 of 11 (permalink) Old 12-10-2005, 15:48
Car: Rover 75 V8
another one here
ebay 2
MikeM is offline
post #11 of 11 (permalink) Old 13-10-2005, 08:20 Thread Starter
Thank you both
Thanks to you both.
I will investigate internals and if necessary take the e bay route for bits.
Regards Mike D
miked7 is offline
instrument cluster upgrade fulhamfan MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 29-10-2008 00:46
214 Instrument Cluster Oyster45 'R8' Rovers (aka Wedges!!) 1 21-12-2007 01:06
75 Tourer Instrument Cluster needed dwatson MG ZT / Rover 75 (Sponsored by Rimmer Bros) 25 09-09-2007 16:14
414I Instrument Cluster Soupdragon Others 5 28-12-2004 19:26
No instrument cluster lights!!! HELP!!!! thager In-Car Audio, Entertainment, Sat Nav etc... 4 19-12-2004 09:56
