post #1 of 33 (permalink) Old 15-09-2010, 20:26 Thread Starter
Lightbulb DIY Foglight Wiring Loom
Phew! Finished (well.. practically finished) my foglight wiring loom, built from scratch apart from a pair of Rover 75 bulb connectors - just a few minor connections to make and it's done, but midges got the better of me tonight.
I started off building a smaller test loom (below) before satisfying myself that it worked, and have now scaled it up. Further pics and How To to follow...
jrproudfoot is offline
post #2 of 33 (permalink) Old 15-09-2010, 20:33
Car: MG TF 160 vvc
good Job i wont to do this
craigraves is offline
post #3 of 33 (permalink) Old 15-09-2010, 22:40 Thread Starter
HOW TO DIY YOUR FOG LIGHT WIRING LOOM
Comments and suggestions are welcome, detailed pics will be inserted over next couple of days, but let me know if there's anything I need to show in more detail - bear in mind I am a complete amateur at this! Note also that I am wiring mine as 'standard' - the foglights will only operate if your lights are switched on, so you can't swan around with just your foglights on using this build. If you want that, you need to take a positive feed from a permanently live wire rather than the sidelight wire highlighted below. The following assumes you have sourced and fitted the foglights and brackets to the bumper, but let me know if you need any advice for that (dead easy).
Shopping List
Rover 75 fog light loom - paid 20 off ebay for mine, free from scrappy (check connectors match that shown in pics below, other Rover/Landrover looms may be suitable)
Front Fog light Switch
Relay (I used the older chunky yellow relay YWB10012 as it fits into the mounting bracket)
Relay Mounting Bracket/bolt for mounting
17amp wire (Halfords) I used just red and black but coloured would be useful for tracing
Male/female spade connectors (large enough to fit relay posts, approx 6-7mm wide, and switch posts, approx 3-4mm)
Earth ring connectors
Scotch clips (temporary measure only - replace these with 'proper' connectiors, e.g. soldering or piggyback spade connectors at earliest opportunity)
In-line fuse holder and fuse (25amp)
Electrician tape
Cable ties
Long rod/cane
Basic tools (wire stripper would be handy though)
PLEASE TAKE ALL THE USUAL PRECAUTIONS WHEN WORKING WITH AUTOMOTIVE ELECTRICS - DISCONNECT YOUR BATTERY NEGATIVE (BLACK) WIRE BEFORE COMMENCING. AS WITH ALL HOW TO'S, FOLLOW THESE INSTRUCTIONS AT YOUR OWN RISK.
First of all, identify the hole blanking grommet, and remove. Pierce a small hole in the centre of this grommet and REMEMBER to thread wires through the grommet as you pass them through the hole. This helps hold the wires in place and preserves the seal. Poke a long cane or rod through this hole and wiggle until you can see the rod in the passenger foot well, behind the glove box (it'll be behind the carpeting if you can't see it). Use the rod and some tape to help you maneuver wires through the bulkhead hole. With all wires, ensure you leave some slack to play with BEFORE you cut the lengths - better to have wires that are slightly too long than too short! Finally, before we start chopping up wires, identify the area where we will mount the relay bracket so that we know where we are running our wires to - I have chosen to use a pre-existing mounting hole near to the fuse box to attach the bracket, hopefully you have it too. Mount the bracket using a suitable bolt (but leave the relay for now).
1) Remove centre console (link), and remove blank for fog light switch. (Note that the bank of switches here are 'keyed', but you can remove the 'key' using a sharp blade and rearrange the switches/blanks however you wish.)
2) Examine fog light switch Connectors, on rear of switch labeled 1 to 5.
5 = ground, 4 = Relay post 86, 3 = not used, 1 and 2 = Positive feed from sidelights
3) Switch connector 5 is to be grounded. Run wire from under bonnet area, through the grommet and bulkhead and into passenger foot well, then behind the centre console and through the switch hole in the console. Connect end of black wire to a small male spade connector, wrapped in electrical tape to prevent it contacting neighboring posts, and attach to connector 5 (see pic above). Run the other end of the wire to the grounding point behind the right hand headlight, shown below, and attach an earth ring connector. Don't connect just yet.
4) Switch connector 4 will be connected to post 86 on the relay. Instructions are identical to above except I used red wire, and terminated the wire with a large spade connector close to the mounting hole for connection to the relay later.
5) Switch connector 3 is not used.
6) Switch connectors 2 and 1 will require a positive feed from sidelights (in order to trigger the relay and illuminate switch). Instructions are again identical to above (I used red wire), except you will need to use a scotch clip to branch the wire so that you can connect it to both terminals. Under the bonnet, you must splice the other end of the wire onto the sidelight positive feed. This should be a red/black striped wire in the cluster behind the right hand side headlight unit (you may need to strip off some of the black tape to get a decent exposed length). Piggyback your wire onto this one.
7) You can now install the fog light switch and replace the centre console. Tuck your wiring up behind glove box and dash and secure with cable ties or similar.
8) Next we will connect the fog lights themselves. You can reach up under the bumper and fit the connectors from the loom, no problem at all. It's also easy to route the wires up along the right hand side of the radiator. My loom had two wires, a positive and a ground - the positive had a spade connector, and was routed up near to the mounting hole for attachment to the relay later. The ground wire had an earth ring connector already attached (put one on if yours hasn't) - route this near to the same ground point as previously shown, for connection later. Any slack wiring hanging from below the bumper needs to be secure up out of the way using cable ties.
9) We need to run a wire from the battery to the relay. Run a red wire from the battery positive terminal to the mounting hole - at the relay end of the cable, attach a female spade terminal - at the battery end, fix an earth ring connector and attach the ring to the battery positive clamp, underneath the existing bolt. The in-line fuse connector (with fuse) needs to be spliced into this wire, close to the battery.
10) We're now ready to install the relay. I found it useful to write the terminal numbers on the side of the relay at this point, as you won't be able to see underneath once it's in the bracket. Slot the relay into the bracket.
11) You're now ready to make the final connections. Connect the wire from the battery to relay terminal 30. Connect the wire from the switch to relay terminal 86. Connect the positive wire from the fog lights to relay terminal 87.
12) Relay terminal 85 needs to be grounded, so prepare a black wire with a spade connector at one end to be attached to relay terminal 85, and an earth ring connector at the other end. Remove the bolt from the ground point as shown earlier, and attach the three earth rings you have made - from the relay, switch and lights.
13) Test! Reconnect battery negative terminal, switch on sidelights and press the button. Fog lights should now illuminate.
14) Finish up by tidying all wiring and taping into place. I also used tape to seal and secure individual connections, especially around the relay and any that seemed exposed. If you used scotch clips (tool of the devil) then remember to replace them for more resilient connections in the future - I'll be soldering mine.
That's it, good luck!
post #4 of 33 (permalink) Old 15-09-2010, 22:50
Car: MGF, Mercedes SLK, Renault clio, Honda VFR 800, SV 650s, Gs500, sr125, ybr125, 50cc, VW Polo,
Nice bit of how to there buddy, however a tip, DITCH the scotch locks they ievitable give problems after a while and can damage the wire itself.
Go for soldering and heat shrink wrapping as it is a more permanent, trouble free job. at the least use the small terminal blocks to do the same job and then wrap well in insulation tape...
Repped for your efforts good post.
Thats better..1
philmgf is offline
post #5 of 33 (permalink) Old 15-09-2010, 22:53 Thread Starter
Noted about the scotch clips - I hate them, but they're all I had left. Will amend above to point this out, thanks.
post #6 of 33 (permalink) Old 15-09-2010, 22:54
Car: MG TF 135 Sprint
Nice post, shame you didn't take pictures as you were doing the job..........nevertheless nicely explained, good job
EDIT: Sorry just seen the thumbnails at the bottom, rep added.............can it be made sticky??
MG_TF_2004 is offline
post #7 of 33 (permalink) Old 15-09-2010, 23:03 Thread Starter
Pics are coming - posting what i have just now, but more to come.
post #8 of 33 (permalink) Old 16-09-2010, 09:00
Car: MGTF 160, Beetle RSi, Porsche 968 CS
That looks great - could you please tell me how easy it was to fit the fog lights, do they ned any special mountings or brackets?
Freakmode is offline
post #9 of 33 (permalink) Old 16-09-2010, 10:30 Thread Starter
Freakmode, the lights themselves were dead easy to fit (and fairly cheap too, won mine on ebay, 25 for the pair). You do need a matching pair of brackets - try to get these with the lights if you can, but if not can be bought seperately.
The brackets are available from Rimmer Bros/Brown & Gammons, different part numbers for left and right hand; Left hand DPL000190, Right hand DPL000180, They were relatively cheap compared to ebay prices at 32 for the pair.
To fit, it's best if you remove the bumper, fix the brackets in with some short self-tapping screws (4mm diameter/8mm long max or you could pierce through to the other side of the bumper) , then the lights just screw into the bracket. Simples.
post #10 of 33 (permalink) Old 16-09-2010, 14:06
Cheers for that I'll order some up - makes the front look a whole lot better
post #11 of 33 (permalink) Old 16-09-2010, 14:51
Are they specific ones that fit a TF or will other Rover models do?
post #12 of 33 (permalink) Old 16-09-2010, 14:58 Thread Starter
The TF ones are fairly universal and have appeared on other Rovers - best bet is to show us the ones you are interested in and we'll cast our critical eyes upon them
post #13 of 33 (permalink) Old 16-09-2010, 20:24 Thread Starter
I mentioned above that the switches on the bank under the heater controls are 'keyed' and will normally fit only in their requisite hole. However, if like me, you want symmetry, you can remove the key strip on the switches and blanks to allow you to position them wherever you like. The keys are very slight raised strips on the switch casing, and can easily be removed with a sharp blade (careful kiddies!).
Key location, with key strips removed.
Now you can rearrange your switches however you like!
post #14 of 33 (permalink) Old 19-09-2010, 21:46
Car: MGTF 160 VVC
Fitting Front Fogs
Thanks for this excellent How To. I have gone the same route as you with the Rover 75 loom but so far have wimped out actually fitting it. I've got all the parts except the relay. Where did you get the relay holder from, please? Does it come with the relay?
Thanks to you sharing your knowledge, I now feel confident fitting the fogs and wiring them up.
Regards,
Richard
rgsmg53 is offline
post #15 of 33 (permalink) Old 19-09-2010, 22:46 Thread Starter
Hey richard, best advice is to make it small to begin with... I've never tinkered with car electrics and I was bricking it, but I found by making a smaller 'test loom' I got it all right in my head before progressing.
Couple of extra tips.. make certain you have enough wiring... I wish i had measured it all to give you a better idea how much you need. I did waste a lot of mine making the test loom, so I reckon in total i used about 5 metres!
I used the chunky yellow 4 pin relay, rather than the smaller black 5 pin, simply because I understood how the 4 pin worked!
The relay holder is cheap as chips... they are universal, able to hold a wide variety of relays. I got mine from this guy.
One last thing that may help you get it right is this diagram I copied out and sat under the hood as a guide
Good luck, if I can do it I think anyone can!
post #16 of 33 (permalink) Old 20-09-2010, 21:07
Car: MGTF 160 VVC
Thanks for the info on the relay and holder.
The circuit diagram is an added bonus! Really appreciate you taking the trouble to post links and take the picture.
Richard
rgsmg53 is offline
post #17 of 33 (permalink) Old 24-11-2010, 19:23
Car: 1999 MGF 1.8 mpi
Did this a while back. Thread. post #12
MGFNorway is offline
post #18 of 33 (permalink) Old 24-11-2010, 21:38
I am thinking of changing the way ours is switched.
It is currently on the proper switch but I much prefer the way the rear fogs work. The front fogs come back on the next time you turn the lights on because, as you know, you have to press the switch to turn them off. Its a "press" for on and "press" for off, well ours is anyway.....
I like the way the rear fogs reset themselves. I am going to do this over the weekend and hopefully make a front fog button fit onto a rear fog gubbings, I have a spare plug in loom part for the rear fog switch, and then modify the relay wiring so that it latches via the 12 volt output off pin 87, obviously fusing the output down to the same rating as the side lights.
It will involve a second relay but hay ho, I have plenty knocking about. I think the biggest issue will be changing the front of the switch.
When the side lights are switched off then the front fogs will turn off and won't come back on when the lights are switched on until the front fog switch is pressed....hopefully. Well thats the plan anyway
harbottle is offline
post #19 of 33 (permalink) Old 24-11-2010, 21:59 Thread Starter
I like your plan, let us know how you get on
post #20 of 33 (permalink) Old 09-12-2010, 08:54
Where did you source connectors to fit a H11 bulb? I've tried multiple places including the usual suspects but with no joy (e.g. Halfords, Maplins)
derek_bartram is offline
Rover 75 foglight wiring loom < N I C K > MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 13-11-2008 09:58
Foglight wiring ~LAZYMONKEY~ 'R8' Rovers (aka Wedges!!) 0 14-07-2007 15:56
Foglight wiring harness Tony Williams MGF and MGTF (Sponsored by MGFnTFBITZ) 14 05-02-2007 20:30
Need Turbo Wiring Loom - Have Got A Mk3 Wiring Loom If Wanted To Swap. imranrasool Wanted 1 26-09-2005 20:22
Foglight Loom Query andywhitehurst Others 1 17-01-2005 21:37
