post #1 of 7 (permalink) Old 05-08-2010, 13:24 Thread Starter
Location: Fighting out of Sheffield by way of Newcastle Upon Tyne
Car: MG TF 135
Driver window stuck in down position
Hi drove home on my dinner both driver and passenger window down pulled up started putting windows up passenger side went straight up but driver side got stuck about 6 inches up the juddered it winds back down no prob but only comes up as I say about 6 inches then it stops and judders as the motortries to push it up- so I at the minute it's parked up on the roadside with the drvier window right down the motor seems ok it's like somthings blocking it from winding up any ideas? Cheers
greeva is offline
post #2 of 7 (permalink) Old 05-08-2010, 13:34
Car: S14 200sx. R33 4 door Skyline. Z32 300zx Drift car.
hmmm sounds like a toughy
my first instinct was a nakered motor, but if thats ok i'm not sure, the mechanism itself is pretty simple
it must be wiering/switch if its not the motor
may be worth getting home and wipping the door card off (its not hard and CJJ wrote a how to so you can't go wrong)
that way you can see what the window is doing inside the door
be carful if your putting your hand inside the door tho, could easily get trapped by a moving windnow!
Adam-MGTF is offline
post #3 of 7 (permalink) Old 13-08-2010, 18:20 Thread Starter
Car: MG TF 135
Hi I took the Door card off and had a look the right sideof the door (the easily visible bit on the inside) appeared to be ok the window moved down about 4 " then I get the grinding and the window judders but won't go down any further. It sounds like the grinding is coming from the left side of the door behing where the speaker would be but it's hard to get a clear view due the the door metal on the speaker side of the door. I managed to get the windowback up by pressing the button and physically pulling up the window at the same time. However after pulling it up it immediatley drops down about 1cm so there is a 1cm gap around the door seal a lovely gap for the rain in a usually water tight tf lol. So at the minute I'm not using the driver side window at all- not good can anyone help me out with advice or has anyone had something similar happen ifso what was the fix and how much will it set me back also is it best to take it to an mg specialist or will any garage be able to sort it ?
greeva is offline
post #4 of 7 (permalink) Old 14-08-2010, 14:48 Thread Starter
Car: MG TF 135
Question
Help someone.....................anyone................ ..?
greeva is offline
post #5 of 7 (permalink) Old 14-08-2010, 16:28
Car: MGF MK2 1.8i,BMW 330i
Dont know but i jsut spent two hours inisde the doors. behind where the speaker is is the motor, so its either broken or seized , probably.
Cant say for sure though, so hopefully someone will come along
(of and my windows are no held up with wood and a wooden hammer handle :ekk:
Broon is offline
post #6 of 7 (permalink) Old 14-08-2010, 17:24
I had a similar thing with mine. I thought it must be the motor so dismantled everything and refitted a new motor on to the existing mechanism. This was not that difficult but fiddly and time consuming. I then found it still did not work properly. I tried swapping the switches over left to right and found it was the switch!
You can do this very easily by pulling back the trim where the switches are and pulling off the connector and swapping them over.
I strongly recommend you try this first as it is a five minute job. I wish I had!
If you need a switch they are usually a fiver on ebay.
good luck and I hope it's the switch
ross2747 is offline
post #7 of 7 (permalink) Old 16-08-2010, 13:14 Thread Starter
Car: MG TF 135
As of yesterday I have the same problem with the passenger side windowing get the grinding and won't go up or down without manually pulling it up does this sound like the motor if so how much to get it fixed?
greeva is offline
Passenger side window stuck in down position martinbamford MGF and MGTF (Sponsored by MGFnTFBITZ) 11 14-10-2010 13:58
Help! Weird Elec Window Issue and window now stuck open! Teachessail MG ZS / Rover 45 & 400 3 29-07-2010 17:35
Driver seat stuck in highest position. Allegro steve MG ZS / Rover 45 & 400 1 20-06-2008 21:35
Rear Folding seat stuck in upright position john71180 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 15-12-2006 08:29
Renault Aims For Pole Position With Unveiling Of Most Driver-focused Hot Megane Yet Ian New Model News 0 04-10-2006 21:10
