LinkBack Thread Tools Rating: Thread Rating: 42 votes, 5.00 average. Display Modes
post #41 of 189 (permalink) Old 31-08-2007, 12:38
I have phoned and asked these guys (http://www.ukobd.co.uk/gstore/store/...p?idProduct=90) if scangauge 2 will work with mems2 and was told no. They also told me that it will only work with mems3.
Yigit is offline
post #42 of 189 (permalink) Old 31-08-2007, 12:42
Car: MG TF 135
Originally Posted by Broon View Post
Sounds VERy good to me
There are millions of OBD lists on the net. Some of them give you nice explanations of what they mean too,
How about just linking to the site isntead of posting the list?
Why didn't I think of that
http://www.autotechnical.co.uk/OBDII%20codes.asp
Mike
MikeS is offline
post #43 of 189 (permalink) Old 31-08-2007, 19:27
Car: MG TF 115
Just ordered the ScanGauge 2 for my 04 TF. Got discount too
I hope it's as good as I'm told! Can't wait!
Janice is offline
post #44 of 189 (permalink) Old 31-08-2007, 19:28
Car: MG TF + MG ZR + MG BGT + MG ZR-R+MG3
Janice, you wont be disappointed.
GazSuttonUK is offline
post #45 of 189 (permalink) Old 03-09-2007, 09:11
I spoke to Derek from UKOBD about the scangauge. It definetely is not compatible with mems 1.9 or mem2j. He believes some function will work but deleting the error codes and etc will not work. He also gave me this link http://www.tuning-diesels.com/index2n.htm for a review of the scangauge.
Yigit is offline
post #46 of 189 (permalink) Old 03-09-2007, 10:59
Car: Please Select
This is the problem that I believe ´99 cars are facing as well. As indicated in my previous posts (about pin 4 and 5 being grounded on non OBD cars)
http://tuning-diesels.com/Eobd/pcbmod.htm
I think upon inspecting your ´99 diagnostic socket, you will find it has similar missing connections as the above.
I don´t need to clear codes. Simply reading sensor data is what I am after.
jupilerman is offline
post #47 of 189 (permalink) Old 05-09-2007, 08:57
Probably not what you want to hear, but this tool is the most cost effective way of getting access to the earlier ECU's (does cover all ECU's), but at a cost - depends on whether you are keeping the car long-term!
The ECU's covered are listed on this coverage document,
Hope that this helps,
Gareth
UKOBD
UKOBD is offline
post #48 of 189 (permalink) Old 05-09-2007, 10:08
Car: MG TF 115
Received my ScanGauge2 yesterday, I'm very pleased.
I fitted it above the rear view mirror, pipping the cable around the trim above the windscreen and down behind the O/S A-post trim and under the dash, then securing the plug into my Diagnostic socket.
- I secured the gauge to the central windscreen trim using a strip of velcro the length of the Gauge although I think double-sided tape might be better.
- As for the cable along the central windscreen trim leading to the O/S A-post, I need something to secure it better. I want it easy to remove if I need to check out another car... so I don't particulary want to put it behind the trim. Placing part of the cable behind the A-post was simple due to a bit of a gap...as was putting it behind the dash - easy removed.
PS, I'd put a photo on.. but I don't think I could attach it to this thread...?
Where have you fitted your ScanGauge2?
Janice is offline
post #49 of 189 (permalink) Old 05-09-2007, 15:13
Car: Please Select
Originally Posted by UKOBD View Post
For the enthousiast indeed, that price is a little steep. But if you´re seriously into it, that price is one of the best out there.
post #50 of 189 (permalink) Old 05-09-2007, 15:16 Thread Starter
Car: MGF MK2 1.8i,BMW 330i
547 pounds. Could probably save you that in a few years on pointless garage visits.
Perhaps.
Broon is offline
post #51 of 189 (permalink) Old 05-09-2007, 22:26
If you have a laptop, Avon is only £125, I plugged into a Mems2j the other day no problem. Dont be put off by the online price list, I am sure they dont yet list the MEMS3 lite version that I have which gives codes, clears, live date and ecu/immobiliser code reading and re-matching.
Here are some MEMS3 codes I have, unfortunately the list is incomplete, I would so, so, so love to have a copy of the official mgr list. If anyone has the complete list, I am sure that some people must have them, please please please let me have a copy!!!! In particular I would love to see MGR's description for P1520.
As you can probably see MGR's codes above P1000 bear little resemblence to 'generic' listings..........
"00 01""P0001""Fuel Volume Regulator Control Circuit/Open"
"00 02""P0002""Fuel Volume Regulator Control Circuit Range/Performance"
"00 03""P0003""Fuel Volume Regulator Control Circuit Low"
"00 04""P0004""Fuel Volume Regulator Control Circuit High"
"00 05""P0005""Fuel Shutoff Valve A Control Circuit/Open"
"00 06""P0006""Fuel Shutoff Valve A Control Circuit Low"
"00 07""P0007""Fuel Shutoff Valve A Control Circuit High"
"00 08""P0008""Engine Position System Performance"
"00 09""P0009""Engine Position System Performance"
"00 10""P0010""A Camshaft Position Actuator Circuit"
"00 11""P0011""A Camshaft Position - Timing Over-Advanced or System Performance"
"00 12""P0012""A Camshaft Position - Timing Over-Retarded"
"00 13""P0013""B Camshaft Position - Actuator Circuit"
"00 14""P0014""B Camshaft Position - Timing Over-Advanced or System Performance"
"00 15""P0015""B Camshaft Position - Timing Over-Retarded"
"00 16""P0016""Crankshaft Position - Camshaft Position Correlation"
"00 17""P0017""Crankshaft Position - Camshaft Position Correlation"
"00 18""P0018""Crankshaft Position - Camshaft Position Correlation"
"00 19""P0019""Crankshaft Position - Camshaft Position Correlation"
"00 20""P0020""A Camshaft Position Actuator Circuit"
"00 21""P0021""A Camshaft Position - Timing Over-Advanced or System Performance"
"00 22""P0022""A Camshaft Position - Timing Over-Retarded"
"00 23""P0023""B Camshaft Position - Actuator Circuit"
"00 24""P0024""B Camshaft Position - Timing Over-Advanced or System Performance"
"00 25""P0025""B Camshaft Position - Timing Over-Retarded"
"00 26""P0026""Intake Valve Control Solenoid Circuit Range/Performance"
"00 27""P0027""Exhaust Valve Control Solenoid Circuit Range/Performance"
"00 28""P0028""Intake Valve Control Solenoid Circuit Range/Performance"
"00 29""P0029""Exhaust Valve Control Solenoid Circuit Range/Performance"
"00 30""P0030""HO2S Heater Control Circuit"
"00 31""P0031""HO2S Heater Control Circuit Low"
"00 32""P0032""HO2S Heater Control Circuit High"
"00 33""P0033""Turbo Charger Bypass Valve Control Circuit"
"00 34""P0034""Turbo Charger Bypass Valve Control Circuit Low"
"00 35""P0035""Turbo Charger Bypass Valve Control Circuit High"
"00 36""P0036""HO2S Heater Control Circuit"
"00 37""P0037""HO2S Heater Control Circuit Low"
"00 38""P0038""HO2S Heater Control Circuit High"
"00 39""P0039""Turbo/Super Charger Bypass Valve Control Circuit Range/Performance"
"00 40""P0040""O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1"
"00 41""P0041""O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2"
"00 42""P0042""HO2S Heater Control Circuit"
"00 43""P0043""HO2S Heater Control Circuit Low"
"00 44""P0044""HO2S Heater Control Circuit High"
"00 45""P0045""Turbo/Super Charger Boost Control Solenoid Circuit/Open"
"00 46""P0046""Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance"
"00 47""P0047""Turbo/Super Charger Boost Control Solenoid Circuit Low"
"00 48""P0048""Turbo/Super Charger Boost Control Solenoid Circuit High"
"00 49""P0049""Turbo/Super Charger Turbine Overspeed"
"00 50""P0050""HO2S Heater Control Circuit"
"00 51""P0051""HO2S Heater Control Circuit Low"
"00 52""P0052""HO2S Heater Control Circuit High"
"00 53""P0053""HO2S Heater Resistance"
"00 54""P0054""HO2S Heater Resistance"
"00 55""P0055""HO2S Heater Resistance"
"00 56""P0056""HO2S Heater Control Circuit"
"00 57""P0057""HO2S Heater Control Circuit Low"
"00 58""P0058""HO2S Heater Control Circuit High"
"00 59""P0059""HO2S Heater Resistance"
"00 60""P0060""HO2S Heater Resistance"
"00 61""P0061""HO2S Heater Resistance"
"00 62""P0062""HO2S Heater Control Circuit"
"00 63""P0063""HO2S Heater Control Circuit Low"
"00 64""P0064""HO2S Heater Control Circuit High"
"00 65""P0065""Air Assisted Injector Control Range/Performance"
"00 66""P0066""Air Assisted Injector Control Circuit or Circuit Low"
"00 67""P0067""Air Assisted Injector Control Circuit High"
"00 68""P0068""MAP/MAF - Throttle Position Correlation"
"00 69""P0069""Manifold Absolute Pressure - Barometric Pressure Correlation"
"00 70""P0070""Ambient Air Temperature Sensor Circuit"
"00 71""P0071""Ambient Air Temperature Sensor Range/Performance"
"00 72""P0072""Ambient Air Temperature Sensor Circuit Low"
"00 73""P0073""Ambient Air Temperature Sensor Circuit High"
"00 74""P0074""Ambient Air Temperature Sensor Circuit Intermittent"
"00 75""P0075""Intake Valve Control Solenoid Circuit"
"00 76""P0076""Intake Valve Control Solenoid Circuit Low"
"00 77""P0077""Intake Valve Control Solenoid Circuit High"
"00 78""P0078""Exhaust Valve Control Solenoid Circuit"
"00 79""P0079""Exhaust Valve Control Solenoid Circuit Low"
"00 80""P0080""Exhaust Valve Control Solenoid Circuit High"
"00 81""P0081""Intake Valve Control Solenoid Circuit"
"00 82""P0082""Intake Valve Control Solenoid Circuit Low"
"00 83""P0083""Intake Valve Control Solenoid Circuit High"
"00 84""P0084""Exhaust Valve Control Solenoid Circuit"
"00 85""P0085""Exhaust Valve Control Solenoid Circuit Low"
"00 86""P0086""Exhaust Valve Control Solenoid Circuit High"
"00 87""P0087""Fuel Rail/System Pressure - Too Low"
"00 88""P0088""Fuel Rail/System Pressure - Too High"
"00 89""P0089""Fuel Pressure Regulator 1 Performance"
"00 90""P0090""Fuel Pressure Regulator 1 Control Circuit"
"00 91""P0091""Fuel Pressure Regulator 1 Control Circuit Low"
"00 92""P0092""Fuel Pressure Regulator 1 Control Circuit High"
"00 93""P0093""Fuel System Leak Detected - Large Leak"
"00 94""P0094""Fuel System Leak Detected - Small Leak"
"00 95""P0095""Intake Air Temperature Sensor 2 Circuit"
"00 96""P0096""Intake Air Temperature Sensor 2 Circuit Range/Performance"
"00 97""P0097""Intake Air Temperature Sensor 2 Circuit Low"
"00 98""P0098""Intake Air Temperature Sensor 2 Circuit High"
"00 99""P0099""Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic"
"01 00""P0100""Mass or Volume Air Flow Circuit"
"01 01""P0101""Mass or Volume Air Flow Circuit Range/Performance"
"01 02""P0102""Mass or Volume Air Flow Circuit Low Input"
"01 03""P0103""Mass or Volume Air Flow Circuit High Input"
"01 04""P0104""Mass or Volume Air Flow Circuit Intermittent"
"01 05""P0105""Manifold Absolute Pressure/Barometric Pressure Circuit"
"01 06""P0106""Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance"
"01 07""P0107""Manifold Absolute Pressure/Barometric Pressure Circuit Low Input"
"01 08""P0108""Manifold Absolute Pressure/Barometric Pressure Circuit High Input"
"01 09""P0109""Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent"
"01 10""P0110""Intake Air Temperature Sensor 1 Circuit"
"01 11""P0111""Intake Air Temperature Sensor 1 Circuit Range/Performance"
"01 12""P0112""Intake Air Temperature Sensor 1 Circuit Low"
"01 13""P0113""Intake Air Temperature Sensor 1 Circuit High"
"01 14""P0114""Intake Air Temperature Sensor 1 Circuit Intermittent"
"01 15""P0115""Engine Coolant Temperature Circuit"
"01 16""P0116""Engine Coolant Temperature Circuit Range/Performance"
"01 17""P0117""Engine Coolant Temperature Circuit Low"
"01 18""P0118""Engine Coolant Temperature Circuit High"
"01 19""P0119""Engine Coolant Temperature Circuit Intermittent"
"01 20""P0120""Throttle/Pedal Position Sensor/Switch A Circuit"
"01 21""P0121""Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance"
"01 22""P0122""Throttle/Pedal Position Sensor/Switch A Circuit Low"
"01 23""P0123""Throttle/Pedal Position Sensor/Switch A Circuit High"
"01 24""P0124""Throttle/Pedal Position Sensor/Switch A Circuit Intermittent"
"01 25""P0125""Insufficient Coolant Temperature for Closed Loop Fuel Control"
"01 26""P0126""Insufficient Coolant Temperature for Stable Operation"
"01 27""P0127""Intake Air Temperature Too High"
"01 28""P0128""Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)"
"01 29""P0129""Barometric Pressure Too Low"
"01 30""P0130""O2 Sensor Circuit"
"01 31""P0131""O2 Sensor Circuit Low Voltage"
"01 32""P0132""O2 Sensor Circuit High Voltage"
"01 33""P0133""O2 Sensor Circuit Slow Response"
"01 34""P0134""O2 Sensor Circuit No Activity Detected"
"01 35""P0135""O2 Sensor Heater Circuit"
"01 36""P0136""O2 Sensor Circuit"
"01 37""P0137""O2 Sensor Circuit Low Voltage"
"01 38""P0138""O2 Sensor Circuit High Voltage"
"01 39""P0139""O2 Sensor Circuit Slow Response"
"01 40""P0140""O2 Sensor Circuit No Activity Detected"
"01 41""P0141""O2 Sensor Heater Circuit"
"01 42""P0142""O2 Sensor Circuit"
"01 43""P0143""O2 Sensor Circuit Low Voltage"
"01 44""P0144""O2 Sensor Circuit High Voltage"
"01 45""P0145""O2 Sensor Circuit Slow Response"
"01 46""P0146""O2 Sensor Circuit No Activity Detected"
"01 47""P0147""O2 Sensor Heater Circuit"
"01 48""P0148""Fuel Delivery Error"
"01 49""P0149""Fuel Timing Error"
"01 50""P0150""O2 Sensor Circuit"
"01 51""P0151""O2 Sensor Circuit Low Voltage"
"01 52""P0152""O2 Sensor Circuit High Voltage"
"01 53""P0153""O2 Sensor Circuit Slow Response"
"01 54""P0154""O2 Sensor Circuit No Activity Detected"
"01 55""P0155""O2 Sensor Heater Circuit"
"01 56""P0156""O2 Sensor Circuit"
"01 57""P0157""O2 Sensor Circuit Low Voltage"
"01 58""P0158""O2 Sensor Circuit High Voltage"
"01 59""P0159""O2 Sensor Circuit Slow Response"
"01 60""P0160""O2 Sensor Circuit No Activity Detected"
"01 61""P0161""O2 Sensor Heater Circuit"
"01 62""P0162""O2 Sensor Circuit"
"01 63""P0163""O2 Sensor Circuit Low Voltage"
"01 64""P0164""O2 Sensor Circuit High Voltage"
"01 65""P0165""O2 Sensor Circuit Slow Response"
"01 66""P0166""O2 Sensor Circuit No Activity Detected"
"01 67""P0167""O2 Sensor Heater Circuit"
"01 68""P0168""Fuel Temperature Too High"
"01 69""P0169""Incorrect Fuel Composition"
"01 70""P0170""Fuel Trim"
"01 71""P0171""System Too Lean"
"01 72""P0172""System Too Rich"
"01 73""P0173""Fuel Trim"
"01 74""P0174""System Too Lean"
"01 75""P0175""System Too Rich"
"01 76""P0176""Fuel Composition Sensor Circuit"
"01 77""P0177""Fuel Composition Sensor Circuit Range/Performance"
"01 78""P0178""Fuel Composition Sensor Circuit Low"
"01 79""P0179""Fuel Composition Sensor Circuit High"
"01 80""P0180""Fuel Temperature Sensor A Circuit"
"01 81""P0181""Fuel Temperature Sensor A Circuit Range/Performance"
"01 82""P0182""Fuel Temperature Sensor A Circuit Low"
"01 83""P0183""Fuel Temperature Sensor A Circuit High"
"01 84""P0184""Fuel Temperature Sensor A Circuit Intermittent"
"01 85""P0185""Fuel Temperature Sensor B Circuit"
"01 86""P0186""Fuel Temperature Sensor B Circuit Range/Performance"
"01 87""P0187""Fuel Temperature Sensor B Circuit Low"
"01 88""P0188""Fuel Temperature Sensor B Circuit High"
"01 89""P0189""Fuel Temperature Sensor B Circuit Intermittent"
"01 90""P0190""Fuel Rail Pressure Sensor Circuit"
"01 91""P0191""Fuel Rail Pressure Sensor Circuit Range/Performance"
"01 92""P0192""Fuel Rail Pressure Sensor Circuit Low"
"01 93""P0193""Fuel Rail Pressure Sensor Circuit High"
"01 94""P0194""Fuel Rail Pressure Sensor Circuit Intermittent"
"01 95""P0195""Engine Oil Temperature Sensor"
"01 96""P0196""Engine Oil Temperature Sensor Range/Performance"
"01 97""P0197""Engine Oil Temperature Sensor Low"
"01 98""P0198""Engine Oil Temperature Sensor High"
"01 99""P0199""Engine Oil Temperature Sensor Intermittent"
"02 00""P0200""Injector Circuit/Open"
"02 01""P0201""Injector Circuit/Open - Cylinder 1"
"02 02""P0202""Injector Circuit/Open - Cylinder 2"
"02 03""P0203""Injector Circuit/Open - Cylinder 3"
"02 04""P0204""Injector Circuit/Open - Cylinder 4"
"02 05""P0205""Injector Circuit/Open - Cylinder 5"
"02 06""P0206""Injector Circuit/Open - Cylinder 6"
"02 07""P0207""Injector Circuit/Open - Cylinder 7"
"02 08""P0208""Injector Circuit/Open - Cylinder 8"
"02 09""P0209""Injector Circuit/Open - Cylinder 9"
"02 10""P0210""Injector Circuit/Open - Cylinder 10"
"02 11""P0211""Injector Circuit/Open - Cylinder 11"
"02 12""P0212""Injector Circuit/Open - Cylinder 12"
"02 13""P0213""Cold Start Injector 1"
"02 14""P0214""Cold Start Injector 2"
"02 15""P0215""Engine Shutoff Solenoid"
"02 16""P0216""Injector/Injection Timing Control Circuit"
"02 17""P0217""Engine Coolant Over Temperature Condition"
"02 18""P0218""Transmission Fluid Over Temperature Condition"
"02 19""P0219""Engine Overspeed Condition"
"02 20""P0220""Throttle/Pedal Position Sensor/Switch B Circuit"
"02 21""P0221""Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance"
"02 22""P0222""Throttle/Pedal Position Sensor/Switch B Circuit Low"
"02 23""P0223""Throttle/Pedal Position Sensor/Switch B Circuit High"
"02 24""P0224""Throttle/Pedal Position Sensor/Switch B Circuit Intermittent"
"02 25""P0225""Throttle/Pedal Position Sensor/Switch C Circuit"
"02 26""P0226""Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance"
"02 27""P0227""Throttle/Pedal Position Sensor/Switch C Circuit Low"
"02 28""P0228""Throttle/Pedal Position Sensor/Switch C Circuit High"
"02 29""P0229""Throttle/Pedal Position Sensor/Switch C Circuit Intermittent"
"02 30""P0230""Fuel Pump Primary Circuit"
"02 31""P0231""Fuel Pump Secondary Circuit Low"
"02 32""P0232""Fuel Pump Secondary Circuit High"
"02 33""P0233""Fuel Pump Secondary Circuit Intermittent"
"02 34""P0234""Turbo/Super Charger Overboost Condition"
"02 35""P0235""Turbo/Super Charger Boost Sensor A Circuit"
"02 36""P0236""Turbo/Super Charger Boost Sensor A Circuit Range/Performance"
"02 37""P0237""Turbo/Super Charger Boost Sensor A Circuit Low"
"02 38""P0238""Turbo/Super Charger Boost Sensor A Circuit High"
"02 39""P0239""Turbo/Super Charger Boost Sensor B Circuit"
"02 40""P0240""Turbo/Super Charger Boost Sensor B Circuit Range/Performance"
"02 41""P0241""Turbo/Super Charger Boost Sensor B Circuit Low"
"02 42""P0242""Turbo/Super Charger Boost Sensor B Circuit High"
"02 43""P0243""Turbo/Super Charger Wastegate Solenoid A"
"02 44""P0244""Turbo/Super Charger Wastegate Solenoid A Range/Performance"
"02 45""P0245""Turbo/Super Charger Wastegate Solenoid A Low"
"02 46""P0246""Turbo/Super Charger Wastegate Solenoid A High"
"02 47""P0247""Turbo/Super Charger Wastegate Solenoid B"
"02 48""P0248""Turbo/Super Charger Wastegate Solenoid B Range/Performance"
"02 49""P0249""Turbo/Super Charger Wastegate Solenoid B Low"
"02 50""P0250""Turbo/Super Charger Wastegate Solenoid B High"
"02 51""P0251""Injection Pump Fuel Metering Control A (Cam/Rotor/Injector)"
"02 52""P0252""Injection Pump Fuel Metering Control A Range/Performance (Cam/Rotor/Injector)"
"02 53""P0253""Injection Pump Fuel Metering Control A Low (Cam/Rotor/Injector)"
"02 54""P0254""Injection Pump Fuel Metering Control A High (Cam/Rotor/Injector)"
"02 55""P0255""Injection Pump Fuel Metering Control A Intermittent (Cam/Rotor/Injector)"
"02 56""P0256""Injection Pump Fuel Metering Control B (Cam/Rotor/Injector)"
"02 57""P0257""Injection Pump Fuel Metering Control B Range/Performance (Cam/Rotor/Injector)"
"02 58""P0258""Injection Pump Fuel Metering Control B Low (Cam/Rotor/Injector)"
"02 59""P0259""Injection Pump Fuel Metering Control B High (Cam/Rotor/Injector)"
"02 60""P0260""Injection Pump Fuel Metering Control B Intermittent (Cam/Rotor/Injector)"
"02 61""P0261""Cylinder 1 Injector Circuit Low"
"02 62""P0262""Cylinder 1 Injector Circuit High"
"02 63""P0263""Cylinder 1 Contribution/Balance"
"02 64""P0264""Cylinder 2 Injector Circuit Low"
"02 65""P0265""Cylinder 2 Injector Circuit High"
"02 66""P0266""Cylinder 2 Contribution/Balance"
"02 67""P0267""Cylinder 3 Injector Circuit Low"
"02 68""P0268""Cylinder 3 Injector Circuit High"
"02 69""P0269""Cylinder 3 Contribution/Balance"
"02 70""P0270""Cylinder 4 Injector Circuit Low"
"02 71""P0271""Cylinder 4 Injector Circuit High"
"02 72""P0272""Cylinder 4 Contribution/Balance"
"02 73""P0273""Cylinder 5 Injector Circuit Low"
"02 74""P0274""Cylinder 5 Injector Circuit High"
"02 75""P0275""Cylinder 5 Contribution/Balance"
"02 76""P0276""Cylinder 6 Injector Circuit Low"
"02 77""P0277""Cylinder 6 Injector Circuit High"
"02 78""P0278""Cylinder 6 Contribution/Balance"
"02 79""P0279""Cylinder 7 Injector Circuit Low"
"02 80""P0280""Cylinder 7 Injector Circuit High"
"02 81""P0281""Cylinder 7 Contribution/Balance"
"02 82""P0282""Cylinder 8 Injector Circuit Low"
"02 83""P0283""Cylinder 8 Injector Circuit High"
"02 84""P0284""Cylinder 8 Contribution/Balance"
"02 85""P0285""Cylinder 9 Injector Circuit Low"
"02 86""P0286""Cylinder 9 Injector Circuit High"
"02 87""P0287""Cylinder 9 Contribution/Balance"
"02 88""P0288""Cylinder 10 Injector Circuit Low"
"02 89""P0289""Cylinder 10 Injector Circuit High"
"02 90""P0290""Cylinder 10 Contribution/Balance"
"02 91""P0291""Cylinder 11 Injector Circuit Low"
"02 92""P0292""Cylinder 11 Injector Circuit High"
"02 93""P0293""Cylinder 11 Contribution/Balance"
"02 94""P0294""Cylinder 12 Injector Circuit Low"
"02 95""P0295""Cylinder 12 Injector Circuit High"
"02 96""P0296""Cylinder 12 Contribution/Balance"
"02 97""P0297""Vehicle Overspeed Condition"
"02 98""P0298""Engine Oil Over Temperature"
"02 99""P0299""Turbo/Super Charger Underboost"
"03 00""P0300""Random/Multiple Cylinder Misfire Detected"
"03 01""P0301""Cylinder 1 Misfire Detected"
"03 02""P0302""Cylinder 2 Misfire Detected"
"03 03""P0303""Cylinder 3 Misfire Detected"
"03 04""P0304""Cylinder 4 Misfire Detected"
"03 05""P0305""Cylinder 5 Misfire Detected"
"03 06""P0306""Cylinder 6 Misfire Detected"
"03 07""P0307""Cylinder 7 Misfire Detected"
"03 08""P0308""Cylinder 8 Misfire Detected"
"03 09""P0309""Cylinder 9 Misfire Detected"
"03 10""P0310""Cylinder 10 Misfire Detected"
"03 11""P0311""Cylinder 11 Misfire Detected"
"03 12""P0312""Cylinder 12 Misfire Detected"
"03 13""P0313""Misfire Detected with Low Fuel"
"03 14""P0314""Single Cylinder Misfire (Cylinder not Specified)"
"03 15""P0315""Crankshaft Position System Variation Not Learned"
"03 16""P0316""Engine Misfire Detected on Startup (First 1000 Revolutions)"
"03 17""P0317""Rough Road Hardware Not Present"
"03 18""P0318""Rough Road Sensor A Signal Circuit"
"03 19""P0319""Rough Road Sensor B"
"03 20""P0320""Ignition/Distributor Engine Speed Input Circuit"
"03 21""P0321""Ignition/Distributor Engine Speed Input Circuit Range/Performance"
"03 22""P0322""Ignition/Distributor Engine Speed Input Circuit No Signal"
"03 23""P0323""Ignition/Distributor Engine Speed Input Circuit Intermittent"
"03 24""P0324""Knock Control System Error"
"03 25""P0325""Knock Sensor 1 Circuit"
"03 26""P0326""Knock Sensor 1 Circuit Range/Performance"
"03 27""P0327""Knock Sensor 1 Circuit Low"
"03 28""P0328""Knock Sensor 1 Circuit High"
"03 29""P0329""Knock Sensor 1 Circuit Input Intermittent"
"03 30""P0330""Knock Sensor 2 Circuit"
"03 31""P0331""Knock Sensor 2 Circuit Range/Performance"
"03 32""P0332""Knock Sensor 2 Circuit Low"
"03 33""P0333""Knock Sensor 2 Circuit High"
"03 34""P0334""Knock Sensor 2 Circuit Input Intermittent"
"03 35""P0335""Crankshaft Position Sensor A Circuit"
"03 36""P0336""Crankshaft Position Sensor A Circuit Range/Performance"
"03 37""P0337""Crankshaft Position Sensor A Circuit Low"
"03 38""P0338""Crankshaft Position Sensor A Circuit High"
"03 39""P0339""Crankshaft Position Sensor A Circuit Intermittent"
"03 40""P0340""Camshaft Position Sensor A Circuit"
"03 41""P0341""Camshaft Position Sensor A Circuit Range/Performance"
"03 42""P0342""Camshaft Position Sensor A Circuit Low"
"03 43""P0343""Camshaft Position Sensor A Circuit High"
"03 44""P0344""Camshaft Position Sensor A Circuit Intermittent"
"03 45""P0345""Camshaft Position Sensor A Circuit"
"03 46""P0346""Camshaft Position Sensor A Circuit Range/Performance"
"03 47""P0347""Camshaft Position Sensor A Circuit Low"
"03 48""P0348""Camshaft Position Sensor A Circuit High"
"03 49""P0349""Camshaft Position Sensor A Circuit Intermittent"
"03 50""P0350""Ignition Coil Primary/Secondary Circuit"
"03 51""P0351""Ignition Coil A Primary/Secondary Circuit"
"03 52""P0352""Ignition Coil B Primary/Secondary Circuit"
"03 53""P0353""Ignition Coil C Primary/Secondary Circuit"
"03 54""P0354""Ignition Coil D Primary/Secondary Circuit"
"03 55""P0355""Ignition Coil E Primary/Secondary Circuit"
"03 56""P0356""Ignition Coil F Primary/Secondary Circuit"
"03 57""P0357""Ignition Coil G Primary/Secondary Circuit"
"03 58""P0358""Ignition Coil H Primary/Secondary Circuit"
"03 59""P0359""Ignition Coil I Primary/Secondary Circuit"
"03 60""P0360""Ignition Coil J Primary/Secondary Circuit"
"03 61""P0361""Ignition Coil K Primary/Secondary Circuit"
"03 62""P0362""Ignition Coil L Primary/Secondary Circuit"
"03 63""P0363""Misfire Detected - Fueling Disabled"
"03 64""P0364""Reserved"
"03 65""P0365""Camshaft Position Sensor B Circuit"
"03 66""P0366""Camshaft Position Sensor B Circuit Range/Performance"
"03 67""P0367""Camshaft Position Sensor B Circuit Low"
"03 68""P0368""Camshaft Position Sensor B Circuit High"
"03 69""P0369""Camshaft Position Sensor B Circuit Intermittent"
"03 70""P0370""Timing Reference High Resolution Signal A"
"03 71""P0371""Timing Reference High Resolution Signal A Too Many Pulses"
"03 72""P0372""Timing Reference High Resolution Signal A Too Few Pulses"
"03 73""P0373""Timing Reference High Resolution Signal A Intermittent/Erratic Pulses"
"03 74""P0374""Timing Reference High Resolution Signal A No Pulse"
"03 75""P0375""Timing Reference High Resolution Signal B"
"03 76""P0376""Timing Reference High Resolution Signal B Too Many Pulses"
"03 77""P0377""Timing Reference High Resolution Signal B Too Few Pulses"
"03 78""P0378""Timing Reference High Resolution Signal B Intermittent/Erratic Pulses"
"03 79""P0379""Timing Reference High Resolution Signal B No Pulses"
"03 80""P0380""Glow Plug/Heater Circuit A"
"03 81""P0381""Glow Plug/Heater Indicator Circuit"
"03 82""P0382""Glow Plug/Heater Circuit B"
"03 83""P0383""Reserved by document"
"03 84""P0384""Reserved by document"
"03 85""P0385""Crankshaft Position Sensor B Circuit"
"03 86""P0386""Crankshaft Position Sensor B Circuit Range/Performance"
"03 87""P0387""Crankshaft Position Sensor B Circuit Low"
"03 88""P0388""Crankshaft Position Sensor B Circuit High"
"03 89""P0389""Crankshaft Position Sensor B Circuit Intermittent"
"03 90""P0390""Camshaft Position Sensor B Circuit"
"03 91""P0391""Camshaft Position Sensor B Circuit Range/Performance"
"03 92""P0392""Camshaft Position Sensor B Circuit Low"
"03 93""P0393""Camshaft Position Sensor B Circuit High"
"03 94""P0394""Camshaft Position Sensor B Circuit Intermittent"
"04 00""P0400""Exhaust Gas Recirculation Flow"
"04 01""P0401""Exhaust Gas Recirculation Flow Insufficient Detected"
"04 02""P0402""Exhaust Gas Recirculation Flow Excessive Detected"
"04 03""P0403""Exhaust Gas Recirculation Control Circuit"
"04 04""P0404""Exhaust Gas Recirculation Control Circuit Range/Performance"
"04 05""P0405""Exhaust Gas Recirculation Sensor A Circuit Low"
"04 06""P0406""Exhaust Gas Recirculation Sensor A Circuit High"
"04 07""P0407""Exhaust Gas Recirculation Sensor B Circuit Low"
"04 08""P0408""Exhaust Gas Recirculation Sensor B Circuit High"
"04 09""P0409""Exhaust Gas Recirculation Sensor A Circuit"
"04 10""P0410""Secondary Air Injection System"
"04 11""P0411""Secondary Air Injection System Incorrect Flow Detected"
"04 12""P0412""Secondary Air Injection System Switching Valve A Circuit"
"04 13""P0413""Secondary Air Injection System Switching Valve A Circuit Open"
"04 14""P0414""Secondary Air Injection System Switching Valve A Circuit Shorted"
"04 15""P0415""Secondary Air Injection System Switching Valve B Circuit"
"04 16""P0416""Secondary Air Injection System Switching Valve B Circuit Open"
"04 17""P0417""Secondary Air Injection System Switching Valve B Circuit Shorted"
"04 18""P0418""Secondary Air Injection System Control A Circuit"
"04 19""P0419""Secondary Air Injection System Control B Circuit"
"04 20""P0420""Catalyst System Efficiency Below Threshold"
"04 21""P0421""Warm Up Catalyst Efficiency Below Threshold"
"04 22""P0422""Main Catalyst Efficiency Below Threshold"
"04 23""P0423""Heated Catalyst Efficiency Below Threshold"
"04 24""P0424""Heated Catalyst Temperature Below Threshold"
"04 25""P0425""Catalyst Temperature Sensor"
"04 26""P0426""Catalyst Temperature Sensor Range/Performance"
"04 27""P0427""Catalyst Temperature Sensor Low"
"04 28""P0428""Catalyst Temperature Sensor High"
"04 29""P0429""Catalyst Heater Control Circuit"
"04 30""P0430""Catalyst System Efficiency Below Threshold"
"04 31""P0431""Warm Up Catalyst Efficiency Below Threshold"
"04 32""P0432""Main Catalyst Efficiency Below Threshold"
"04 33""P0433""Heated Catalyst Efficiency Below Threshold"
"04 34""P0434""Heated Catalyst Temperature Below Threshold"
"04 35""P0435""Catalyst Temperature Sensor"
"04 36""P0436""Catalyst Temperature Sensor Range/Performance"
"04 37""P0437""Catalyst Temperature Sensor Low"
"04 38""P0438""Catalyst Temperature Sensor High "
"04 39""P0439""Catalyst Heater Control Circuit"
"04 40""P0440""Evaporative Emission System"
"04 41""P0441""Evaporative Emission System Incorrect Purge Flow"
"04 42""P0442""Evaporative Emission System Leak Detected (small leak)"
"04 43""P0443""Evaporative Emission System Purge Control Valve Circuit"
"04 44""P0444""Evaporative Emission System Purge Control Valve Circuit Open"
"04 45""P0445""Evaporative Emission System Purge Control Valve Circuit Shorted"
"04 46""P0446""Evaporative Emission System Vent Control Circuit"
"04 47""P0447""Evaporative Emission System Vent Control Circuit Open"
"04 48""P0448""Evaporative Emission System Vent Control Circuit Shorted"
"04 49""P0449""Evaporative Emission System Vent Valve/Solenoid Circuit"
"04 50""P0450""Evaporative Emission System Pressure Sensor/Switch"
"04 51""P0451""Evaporative Emission System Pressure Sensor/Switch Range/Performance"
"04 52""P0452""Evaporative Emission System Pressure Sensor/Switch Low"
"04 53""P0453""Evaporative Emission System Pressure Sensor/Switch High"
"04 54""P0454""Evaporative Emission System Pressure Sensor/Switch Intermittent"
"04 55""P0455""Evaporative Emission System Leak Detected (large leak)"
"04 56""P0456""Evaporative Emission System Leak Detected (very small leak)"
"04 57""P0457""Evaporative Emission System Leak Detected (fuel cap loose/off)"
"04 58""P0458""Evaporative Emission System Purge Control Valve Circuit Low"
"04 59""P0459""Evaporative Emission System Purge Control Valve Circuit High"
"04 60""P0460""Fuel Level Sensor A Circuit"
"04 61""P0461""Fuel Level Sensor A Circuit Range/Performance"
"04 62""P0462""Fuel Level Sensor A Circuit Low"
"04 63""P0463""Fuel Level Sensor A Circuit High"
"04 64""P0464""Fuel Level Sensor A Circuit Intermittent"
"04 65""P0465""EVAP Purge Flow Sensor Circuit"
"04 66""P0466""EVAP Purge Flow Sensor Circuit Range/Performance"
"04 67""P0467""EVAP Purge Flow Sensor Circuit Low"
"04 68""P0468""EVAP Purge Flow Sensor Circuit High"
"04 69""P0469""EVAP Purge Flow Sensor Circuit Intermittent"
"04 70""P0470""Exhaust Pressure Sensor"
"04 71""P0471""Exhaust Pressure Sensor Range/Performance"
"04 72""P0472""Exhaust Pressure Sensor Low"
"04 73""P0473""Exhaust Pressure Sensor High"
"04 74""P0474""Exhaust Pressure Sensor Intermittent"
"04 75""P0475""Exhaust Pressure Control Valve"
"04 76""P0476""Exhaust Pressure Control Valve Range/Performance"
"04 77""P0477""Exhaust Pressure Control Valve Low"
"04 78""P0478""Exhaust Pressure Control Valve High"
"04 79""P0479""Exhaust Pressure Control Valve Intermittent"
"04 80""P0480""Fan 1 Control Circuit"
"04 81""P0481""Fan 2 Control Circuit"
"04 82""P0482""Fan 3 Control Circuit"
"04 83""P0483""Fan Rationality Check"
"04 84""P0484""Fan Circuit Over Current"
"04 85""P0485""Fan Power/Ground Circuit"
"04 86""P0486""Exhaust Gas Recirculation Sensor B Circuit"
"04 87""P0487""Exhaust Gas Recirculation Throttle Position Control Circuit"
"04 88""P0488""Exhaust Gas Recirculation Throttle Position Control Range/Performance"
"04 89""P0489""Exhaust Gas Recirculation Control Circuit Low"
"04 90""P0490""Exhaust Gas Recirculation Control Circuit High"
"04 91""P0491""Secondary Air Injection System Insufficient Flow"
"04 92""P0492""Secondary Air Injection System Insufficient Flow"
"04 93""P0493""Fan Overspeed"
"04 94""P0494""Fan Speed Low"
"04 95""P0495""Fan Speed High"
"04 96""P0496""Evaporative Emission System High Purge Flow"
"04 97""P0497""Evaporative Emission System Low Purge Flow"
"04 98""P0498""Evaporative Emission System Vent Valve Control Circuit Low"
"04 99""P0499""Evaporative Emission System Vent Valve Control Circuit High"
"05 00""P0500""Vehicle Speed Sensor A"
"05 01""P0501""Vehicle Speed Sensor A Range/Performance"
"05 02""P0502""Vehicle Speed Sensor A Circuit Low Input"
"05 03""P0503""Vehicle Speed Sensor A Intermittent/Erratic/High"
"05 04""P0504""Brake Switch A/B Correlation"
"05 05""P0505""Idle Air Control System"
"05 06""P0506""Idle Air Control System RPM Lower Than Expected"
"05 07""P0507""Idle Air Control System RPM Higher Than Expected"
"05 08""P0508""Idle Air Control System Circuit Low"
"05 09""P0509""Idle Air Control System Circuit High"
"05 10""P0510""Closed Throttle Position Switch"
"05 11""P0511""Idle Air Control Circuit"
"05 12""P0512""Starter Request Circuit"
"05 13""P0513""Incorrect Immobilizer Key"
"05 14""P0514""Battery Temperature Sensor Circuit Range/Performance"
"05 15""P0515""Battery Temperature Sensor Circuit"
"05 16""P0516""Battery Temperature Sensor Circuit Low"
"05 17""P0517""Battery Temperature Sensor Circuit High"
"05 18""P0518""Idle Air Control Circuit Intermittent"
"05 19""P0519""Idle Air Control System Performance"
"05 20""P0520""Engine Oil Pressure Sensor/Switch Circuit"
"05 21""P0521""Engine Oil Pressure Sensor/Switch Range/Performance"
"05 22""P0522""Engine Oil Pressure Sensor/Switch Low Voltage"
"05 23""P0523""Engine Oil Pressure Sensor/Switch High Voltage"
"05 24""P0524""Engine Oil Pressure Too Low"
"05 25""P0525""Cruise Control Servo Control Circuit Range/Performance"
"05 26""P0526""Fan Speed Sensor Circuit"
"05 27""P0527""Fan Speed Sensor Circuit Range/Performance"
"05 28""P0528""Fan Speed Sensor Circuit No Signal"
"05 29""P0529""Fan Speed Sensor Circuit Intermittent"
"05 30""P0530""A/C Refrigerant Pressure Sensor A Circuit"
"05 31""P0531""A/C Refrigerant Pressure Sensor A Circuit Range/Performance"
"05 32""P0532""A/C Refrigerant Pressure Sensor A Circuit Low"
"05 33""P0533""A/C Refrigerant Pressure Sensor A Circuit High"
"05 34""P0534""Air Conditioner Refrigerant Charge Loss"
"05 35""P0535""A/C Evaporator Temperature Sensor Circuit"
"05 36""P0536""A/C Evaporator Temperature Sensor Circuit Range/Performance"
"05 37""P0537""A/C Evaporator Temperature Sensor Circuit Low"
"05 38""P0538""A/C Evaporator Temperature Sensor Circuit High"
"05 39""P0539""A/C Evaporator Temperature Sensor Circuit Intermittent"
"05 40""P0540""Intake Air Heater A Circuit"
"05 41""P0541""Intake Air Heater A Circuit Low"
"05 42""P0542""Intake Air Heater A Circuit High"
"05 43""P0543""Intake Air Heater A Circuit Open"
"05 44""P0544""Exhaust Gas Temperature Sensor Circuit"
"05 45""P0545""Exhaust Gas Temperature Sensor Circuit Low"
"05 46""P0546""Exhaust Gas Temperature Sensor Circuit High"
"05 47""P0547""Exhaust Gas Temperature Sensor Circuit"
"05 48""P0548""Exhaust Gas Temperature Sensor Circuit Low"
"05 49""P0549""Exhaust Gas Temperature Sensor Circuit High"
"05 50""P0550""Power Steering Pressure Sensor/Switch Circuit"
"05 51""P0551""Power Steering Pressure Sensor/Switch Circuit Range/Performance"
"05 52""P0552""Power Steering Pressure Sensor/Switch Circuit Low Input"
"05 53""P0553""Power Steering Pressure Sensor/Switch Circuit High Input"
"05 54""P0554""Power Steering Pressure Sensor/Switch Circuit Intermittent"
"05 55""P0555""Brake Booster Pressure Sensor Circuit"
"05 56""P0556""Brake Booster Pressure Sensor Circuit Range/Performance"
"05 57""P0557""Brake Booster Pressure Sensor Circuit Low Input"
"05 58""P0558""Brake Booster Pressure Sensor Circuit High Input"
"05 59""P0559""Brake Booster Pressure Sensor Circuit Intermittent"
"05 60""P0560""System Voltage"
"05 61""P0561""System Voltage Unstable"
"05 62""P0562""System Voltage Low"
"05 63""P0563""System Voltage High"
"05 64""P0564""Cruise Control Multi-Function Input A Circuit"
"05 65""P0565""Cruise Control On Signal"
"05 66""P0566""Cruise Control Off Signal"
"05 67""P0567""Cruise Control Resume Signal"
"05 68""P0568""Cruise Control Set Signal"
"05 69""P0569""Cruise Control Coast Signal"
"05 70""P0570""Cruise Control Accelerate Signal"
"05 71""P0571""Brake Switch A Circuit"
"05 72""P0572""Brake Switch A Circuit Low"
"05 73""P0573""Brake Switch A Circuit High"
"05 74""P0574""Cruise Control System - Vehicle Speed Too High"
"05 75""P0575""Cruise Control Input Circuit"
"05 76""P0576""Cruise Control Input Circuit Low"
"05 77""P0577""Cruise Control Input Circuit High"
"05 78""P0578""Cruise Control Multi-Function Input A Circuit Stuck"
"05 79""P0579""Cruise Control Multi-Function Input A Circuit Range/Performance"
"05 80""P0580""Cruise Control Multi-Function Input A Circuit Low"
"05 81""P0581""Cruise Control Multi-Function Input A Circuit High"
"05 82""P0582""Cruise Control Vacuum Control Circuit/Open"
"05 83""P0583""Cruise Control Vacuum Control Circuit Low"
"05 84""P0584""Cruise Control Vacuum Control Circuit High"
"05 85""P0585""Cruise Control Multi-Function Input A/B Correlation"
"05 86""P0586""Cruise Control Vent Control Circuit/Open"
"05 87""P0587""Cruise Control Vent Control Circuit Low"
"05 88""P0588""Cruise Control Vent Control Circuit High"
"05 89""P0589""Cruise Control Multi-Function Input B Circuit"
"05 90""P0590""Cruise Control Multi-Function Input B Circuit Stuck"
"05 91""P0591""Cruise Control Multi-Function Input B Circuit Range/Performance"
"05 92""P0592""Cruise Control Multi-Function Input B Circuit Low"
"05 93""P0593""Cruise Control Multi-Function Input B Circuit High"
"05 94""P0594""Cruise Control Servo Control Circuit/Open"
"05 95""P0595""Cruise Control Servo Control Circuit Low"
"05 96""P0596""Cruise Control Servo Control Circuit High"
"05 97""P0597""Thermostat Heater Control Circuit/Open"
"05 98""P0598""Thermostat Heater Control Circuit Low"
"05 99""P0599""Thermostat Heater Control Circuit High"
"06 01""P0601""ROM Check failure "
"06 50""P0650""MIL drive"
"06 55""P0655""Engine bay overheat warning lamp drive"
"07 05""P0705""PRNDL range sensor circuit problem"
"07 22""P0722""transmissions output speed sensor"
"07 30""P0730""Transmission incorrect ratio"
"07 90""P0790""Gearbox NORMAL operation switch"
"08 15""P0815""Gear change UP switch (steering wheel)"
"08 16""P0816""Gear change DOWN switch (steering wheel)"
"11 85""P1185""Upstream oxygen sensor heater - Electrical"
"11 86""P1186""Upstream oxygen sensor heater - Electrical"
"11 91""P1191""Downstream oxygen sensor heater - Electrical"
"11 92""P1192""Downstream oxygen sensor heater - Electrical"
"12 31""P1231""Fuel pump relay"
"12 32""P1232""Fuel pump relay"
"13 00""P1300""misfire causing catalyst damage"
"13 16""P1316""misfire causing emissions problems"
"15 06""P1506""Idle speed control stepper motor drive"
"15 07""P1507""Idle speed control stepper motor drive"
"15 08""P1508""Idle speed control stepper motor drive"
"15 37""P1537""Airconditioning drive"
"15 38""P1538""Airconditioning drive"
"15 90""P1590""rough road sensor fault"
"16 10""P1610""Main relay"
"16 11""P1611""Main relay"
"16 40""P1640""CAN message failure"
"17 75""P1775""Gearbox problem"
"17 85""P1785""GIB over temperature"
"17 87""P1787""stepper motor dirve"
"17 88""P1788""stepper motor dirve"
"18 15""P1815""Gear change UP switch (gear lever)"
"18 16""P1816""Gear change DOWN switch (gear lever)"
"18 30""P1830""PWM link between EMS and GIB"
"18 31""P1831""PWM link between EMS and GIB"
"18 36""P1836""Data from GIB to EMS"
"18 37""P1837""comms link between EMS and inst pack"
"18 38""P1838""comms link between EMS and inst pack"
I can also add-
P1522 Camshaft circuits inc. cam sensor.
P1524 'A' camshaft circuit, solenoid.
P1530 'B' camshaft circuit, solenoid.
touche is offline
post #52 of 189 (permalink) Old 05-09-2007, 22:40 Thread Starter
Fantastic info, cheers
Broon is offline
post #53 of 189 (permalink) Old 05-09-2007, 22:48
Perhaps.
I agree but still cannot justify that price. If i had mems3, i would already have bought sg2.
Yigit is offline
post #54 of 189 (permalink) Old 12-09-2007, 15:40 Thread Starter
Found some really good OBD2 pages.
From a Ford Scorpio website, but will also apply to us
Includes pre, during and post diagnosis/fixing readouts etc.
http://www.fordscorpio.co.uk/obd2scan4.htm
(links on left)
I am liking very much , yes.
Broon is offline
post #55 of 189 (permalink) Old 12-09-2007, 18:43
nice find Broonie :Broon:
post #56 of 189 (permalink) Old 12-09-2007, 19:38
Car: Alfa GTV
shroonie29 is offline
post #57 of 189 (permalink) Old 12-09-2007, 19:41 Thread Starter
Originally Posted by shroonie29 View Post
Fantastic Shroonie
Broon is offline
post #58 of 189 (permalink) Old 12-09-2007, 21:08
noooooooo, its not them, gutted, thats the 'generic' above P1000 list, same as BAT Autotechnical, I think its based on BMW code list, aaaggggggghhhhhhhhhh, someone must have them!
touche is offline
post #59 of 189 (permalink) Old 12-09-2007, 21:12
Car: Alfa GTV
Oh ok.Got list of Dr.Dave on here
post #60 of 189 (permalink) Old 12-09-2007, 22:45
Car: MG TF 160
Chris/Pete - Does the U381 have the Trip computer type information as well as fault diagnosis? Such as fuel, mph, rpm, coolant temperature etc?
Would I be able to easily diagnose faulty sensors?
cheers
kxtzzz is offline
Obd-ii SteveChilds MGF and MGTF (Sponsored by MGFnTFBITZ) 4 21-01-2009 19:45
OBD II or what? Softwarez MG ZR / Rover 25, 200 & Streetwise 3 03-10-2008 22:39
Obd Ii konstantinos Others 7 10-11-2005 00:22
Obd Ii spyne Others 14 29-01-2004 19:33
