post #1 of 9 (permalink) Old 15-02-2011, 22:16 Thread Starter
Tappet noise on cold starting?
I've just taken Margarets TF for petrol, it's been sitting since Monday so is cold.
When I started it there was a fairly loud tappety noise coming, I think, from the top of the engine. It sounded like it could be a sticky valve tapping of the camshaft. After a minute ot two it dissapeared once the engine warmed up.
Has anyone had any similar experiences? It's a TF 115 by the way with 39K on the clock and is due a service.
Cheers,
Bill
Storm is offline
post #2 of 9 (permalink) Old 15-02-2011, 22:31
Car: Ophelia~ a 2004 MGTF 160 in Spectre
As far as I know, this is fairly common and even more so on the vvc engine (though I know yours isn't).
Check your oil level, it may just be a little low if you've noticed it before?
Sure others will be along soon!
Birks is offline
post #3 of 9 (permalink) Old 15-02-2011, 22:36
Car: MGF/BRG/ollie savage.
hi yes i have had the same thing happen so i did add some kind of engine oil addative run it for a few miles then did a full oil and filter change did the trick, i do find that if the oil level gets a little low it seems to come back but only for afew seconds on start up.
youngbill is offline
post #4 of 9 (permalink) Old 16-02-2011, 09:33 Thread Starter
Cheers guys, the levels seemed good only a week or so again but I'll check them again coz you never know when they will drop.
Does the TF have hydraulic tappets? I'm just asking cos the guys with non-MiVEC FTOs have hydraulic tappets and they can describe a similar noise on starting.
Bill
EDIT - just checked the manual and yes, they are hydraulic tappets so a change of oil and a good top end treatment should be all it needs.
Thanks you guys who responded - I can stop panicking now - although I'll start again next week when she mentions something else!
Storm is offline
post #5 of 9 (permalink) Old 16-02-2011, 11:31
Car: MGF MY2000 VVC in Anthracite - yum. XRV750X Africa Twin
Mine does the same (VVC tho') If the car has been stood for a while the tappets will slightly drain of oil until the engine is started again and the pressure fills them back up. I believe it gets more pronounced the older the oil gets due to it being thicker.....bit like me really
Cheesyreich is offline
post #6 of 9 (permalink) Old 16-02-2011, 12:30
I had this problem- on a TF115 too. It's a sticking tappet. I put in some engine flush and changed the oil and filter. Been fine ever since.
TBarry is offline
post #7 of 9 (permalink) Old 11-04-2011, 16:02 Thread Starter
I forgot to service the TF and just got a call from Mags to say her tappet was sticking again and the car wasn't running right, and the Engine Management Light came on
I reckon it will be fuel trim again because I haven't serviced it and if it is sticking as bad as she says it's probably got fouled plugs by now.
I just hope I haven't damamged anything else due to my forgetfulness!
Oh well, Halfords it is tonight then
Storm is offline
post #8 of 9 (permalink) Old 11-04-2011, 18:44
Car: ASTRA CABBY
it could be a lose spark plug
mine did that and ended up using to much fuel then the lamba failed
but sounded just like a cam lobe but after a while got worse so had it checked
i was looky as the plug was nearly out so thread could of striped meaning new head
MGF MARK is offline
post #9 of 9 (permalink) Old 11-04-2011, 18:56
Car: MGF 1.8MPi
Send a message via Skype™ to jordimussol
Tappet noise is quite common. This is because the tappet hasn't enough oil and at cold start the oil is too thick to penetrate inside the hydraulic tappet.
As soon as oil gets a tad warmer (and less dense) it can go into the tappet easier and the noise disappears.
I recently had a very loud tappet noise that didn't want to go away. Put some engine oil treatment and it disappeared in minutes.
LEt the oil get to warm operating temperature and if noise persists, this engine additive. Else, change of oil. If it still remains, then it's something more serious.
jordimussol is offline
tappet noise 825kv6 Rover 800 28 19-03-2010 10:43
Clicking noise when starting engine from cold krit MGF and MGTF (Sponsored by MGFnTFBITZ) 7 27-02-2008 15:00
Sounds like a tappet noise mrnibbler MG ZS / Rover 45 & 400 22 10-12-2006 20:08
Ticking noise when starting from cold korabiowski MG / Rover Related Chat - up to 2005 5 19-05-2006 12:06
Tappet Noise WayneH Rover 600 3 04-05-2003 22:35
