post #1 of 9 (permalink) Old 23-12-2006, 16:13 Thread Starter
Car: Rover 200 (-95)
Clock Bulb ?
Following a thread on here I removed the bulb holder from the back of my digi clock (1993 214I)
I tried changing the bulb but my fat fingers meant I dropped (and lost) one of the metal connectors - bu66er !
Can you buy new holders (inc a bulb) from dealers or do you have to buy a whole clock unit ?
Scooby Towers is offline
post #2 of 9 (permalink) Old 23-12-2006, 16:35
Car: Rover 220 Coupe, ZS180 in T/Blue, ZT190+ in Monogram Typhoon
Send a message via MSN to felpham_ant
Hiya you can buy the whole unit from a scrapyard for a couple of pounds. Or if you prefer the cheaper option you can stick one in your pocket
felpham_ant is offline
post #3 of 9 (permalink) Old 23-12-2006, 16:36
I was gonna say get some scrapyard action on!
empsburna is offline
post #4 of 9 (permalink) Old 24-12-2006, 20:17 Thread Starter
Unhappy
Ahhhhh the old half a tool box on the way in - full as ****** on the way out trick - brings back fond memories
That is until they closed all the scrappies near us & those that are still going do a "we'll get it for you service"
Might have a sniff around in the New year and see if I can find one (legit of course ).
Out of interest does the clock fit in other models & years of car (Metro's etc)?
post #5 of 9 (permalink) Old 24-12-2006, 20:21
the 200 series up to 95 deffinatly has the same clock as does the 400 series up to 95. Unsure of models after that but I'm 99.999% sure the 400 series from 95 also had the same one
post #6 of 9 (permalink) Old 24-12-2006, 21:10
Send a message via MSN to tows971
I thought up to 1995 the clock only told the time? After 95 didnt the clock become multi-function? e.g clock, date and radio station?
tows971 is offline
post #7 of 9 (permalink) Old 28-12-2006, 17:08
Car: RIP Metro, RIP 214SEi, RIP 45 Club TD, RIP 45 Club SE TD :(
I've got one from a later model car, and it's different. It doesn't have the flap over the buttons for a start, and it might be a little larger. I think the connections are different as well, as some of them can be wired up to a traffic master receiver. It takes the same bulbs though. The later 400/45 clocks are very different again.
To those that have done this successfully, how do you get the wooden strip out in one piece? I'm on the verge of replacing my bulb, but breaking the trim strip worries me.
Jelibeli is offline
post #8 of 9 (permalink) Old 31-12-2006, 16:18 Thread Starter
I found that the end nearest the passenger door seemed to be stuck in with glue, so I levered the other end free just enough to get to the clock (without totally removing the strip).
It went back together fine.
For info - Its held with metal clips that easily snap back together - but I'm not sure what holds the passenger side end on.
Hope this helps
post #9 of 9 (permalink) Old 31-12-2006, 16:51
Car: MG ZS 180 Mk2 Ignition Blue hatch
As far as I recall it has tabs on the back which go into metal clips. You have to gently prise the plastic trim from the door end and work your way along. It doesn't have any glue on it as standard!
shufti is offline
dash clock bulb javis9689 MG ZR / Rover 25, 200 & Streetwise 16 27-10-2011 14:56
Changing bulb in clock. Red Devil MGF and MGTF (Sponsored by MGFnTFBITZ) 5 20-08-2008 12:09
Clock bulb blown again dirtyharry MG ZS / Rover 45 & 400 10 08-07-2008 11:01
Clock Bulb PHLEB MGF and MGTF (Sponsored by MGFnTFBITZ) 2 26-06-2008 21:23
ZS Clock bulb mattie007 MG / Rover Related Chat - up to 2005 2 14-02-2008 12:41
