Gearbox oil info needed - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > MG ZR / Rover 25, 200 & Streetwise
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 01-08-2005, 23:23   #1
andywhitehurst
Car: MG ZR
I was thinking about changing the gearbox oil on my rover 200 (1.4 V-reg). It has the original oil in and I was wondering on what peoples views are on changing it?
It seems a bit of a pain to do unless you can get it on a ramp so I am thinking of letting my local mechanic do it for what he would charge for labour and I would just provide the oil.
Which gearbox oil do you recommend?
andywhitehurst is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 06:21   #2
misterreliable
Car: 2004 MG ZR 120+
cant comment on type of oil you should use..but changing it is pretty straight foreward...see here
misterreliable is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 06:25   #3
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Make sure MTF94 oil is used, available from Land Rover or Rover dealers.
It's a fill-for-life oil, no need to change it really.
Dr Dave is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 09:02   #4
jonR200
Car: Rover 200 (95-99) 'Bubble Shape'
i think i used esso stuff and it did make it smoother... prob worth doing and not particularly difficult.
jonR200 is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 09:42   #5
MGJohn
MGJohn's Avatar
Car: MG Montego Turbo; 620ti x3; MGZS; MGF and MG ZT 1.8t x2
Yes, 'fill for life' oil in the gearbox from the factory.
However, it's a good idea to top up the level just in case there has been a slow progressive loss for some reason. Not a difficult job. I find a funnel with a short length of garden hose helps and avoids spillage. If it needs quite a lot to top up, then investigate the reasons for the loss.
After ten years of ownership, I drained the gearbox oil on my 1990 Montego (PG1 box) as I felt it must certainly need changing. That as before I learned about the 'fill for life' gearbox oil. I did that after 100,000 miles and the oil which came out of that gearbox then was as clean and clear as when it left the production line.
Apparently ... in a parallel universe MGJohn drives .........A.......
B>>M>>W ....
Arrrrrggghhhhh......... ......
MGJohn is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 11:03   #6
GONZO
Car: Rover 200 Coupe
Major Ingram Make sure MTF94 oil is used, available from Land Rover or Rover dealers.
Er dont mean to appear rude but no its not!
BV75W-80 is the correct oil for R65 box. Last part number i have for it was VYK000080 from a Rover dealer, 1 litre bottles from memory they take between 2-2.5litres from empty.
GONZO is offline   Reply With Quote Quick reply to this message
Old 02-08-2005, 17:35   #7
misterreliable
I thought the R-65 Gearbox took 1.75 litres from empty to full?
Old 02-08-2005, 18:28   #8
andywhitehurst
Car: MG ZR
So is it worth changing the gearbox oil or just topping it up?
Old 02-08-2005, 18:48   #9
cjmillsnun
Car: MGF Trophy 160 in Trophy Yellow
Send a message via MSN to cjmillsnun
TBH just check the level and top up
cjmillsnun is offline   Reply With Quote Quick reply to this message
Old 03-08-2005, 14:54   #10
GONZO
Amount was a guestimate mate i knew it used ta come in 2.5 litre bottles and you usually got a bit a change out of one from dry.
Sorry probably should of said that above
Old 03-08-2005, 16:46   #11
ashy
Car: Silver Stormer ZR turbo.
Yes maybe, but isn't MTF94 the stuff MGR use in their boxes now and recommend. Better stuff I believe.
ashy is offline   Reply With Quote Quick reply to this message
Old 03-08-2005, 18:29   #12
cjmillsnun
MTF94 is what you need to use in a PG1 box. The R65 needs different oil BV75W-80.
Old 03-08-2005, 19:02   #13
GONZO
Argh that be it matey.
Old 13-09-2006, 12:33   #14
MR TT
Car: Rover 25
Rover 25 Gearbox Oil Change
I'VE TRIED YOUR LINK PUT CANNOT ACCESS IT. COULD YOU TELL ME WERE THE NUTS ARE LOCATED THAT I HAVE TO REMOVE IN ORDER TO CARRY OUT THEAR GEARBOX OIL CHANGE
MR TT is offline   Reply With Quote Quick reply to this message
Where did you hear of this site?
From which source did you hear about us?
Or enter your choice here:
What make of car do you drive?
If you have multiple cars, please use the car you drive the most. Please make sure you fill this field in as it can help others help you.
Your Country
Where are you from in the world!
Your Postcode (UK Only)
Please enter the first part of your postcode (i.e. WS3) This is used soley for targeting advertising, its not visible on the site, nor made available to 3rd parties. If you are not in the UK, please enter N/A
Insurance
Please select your insurance company (Optional)
Any modifications to your car?
If you have made any modifications to your car, please list them here
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
Gearbox oil - sealing washer part # needed! adchelle MGF and MGTF (Sponsored by MGFnTFBITZ) 1 11-11-2008 20:12
Gearbox seals info. CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 8 16-08-2008 10:59
Auto Box Oil Change info needed A S A P please northstand MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 09-12-2007 09:44
gearbox info jasonc46 Rover 600 2 21-10-2006 07:45
PG1 Gearbox Info Dr Dave Others 9 20-01-2003 09:22
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
