Rover 45 TD turbo boost question - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > MG/R Modification & Tuning
Old 18-05-2006, 14:35   #1
henryrym
Car: Rover 45
I've just boosted the turbo pressure on my 45 TD by turning the wastegate actuator screw by approx three turns (as per RoverRon's site - thanks Ron!).
The car feels a somewhat livlier, just curious as to how many extra bhp horses you get for three turns - any one tried a before and after on a rolling road in terms of bhp.
What's the maximum number of turns you can boost the turbo by before damage is caused, is there some mechanism that limits the max boost a turbo can supply, presumably three turns will not reach the pressure boost limit if there is one?
I've fitted a K&N filter (panel type) which also seems to give the engine some power boost. Again any one know what this equates to in bhp terms?
Henry
henryrym is offline   Reply With Quote Quick reply to this message
Old 18-05-2006, 14:37   #2
AndBurG
Car: S60 D5
Send a message via MSN to AndBurG
the difference is negligeable, should take you to about 19psi, 21psi is a boost cut on the L series, 19 is a safe limit. you may have game 4/5bhp from the two combined
AndBurG is offline   Reply With Quote Quick reply to this message
Old 18-05-2006, 21:38   #3
Rover_ron
Car: Other Manufacturer
I don't think there is a boost cut on the 25/45 version of the L series. There definitely is on the sdis though.
I know some owners have run their L series at 23psi apparently without a problem.
The law of diminishng returns comes into play as you up the boost very much because the intercooler efficiency or rather, lack of, means that the compressed air gets hotter.
So you end up with a higher volume of air but its hotter. So you are not mch better off.
Conversely, if you improve the intercooler efficiency you would get a greater air mass for the same pressure due to it being cooler. Hence the 'performance intercooler' exists. Better flow = less pressure drop across it = greater air flow for the same pressure, and better cooling efficiency = denser air.
On my 45, there were only about 3 threads left on the actuator linkage and this gave about 20psi.
Ron
Rover_ron is offline   Reply With Quote Quick reply to this message
Old 19-05-2006, 00:02   #4
E_T_V
Car: Maestros, 200, 600, ZTT
What is the boost cut level on the SDI's and if your tuning box is fitted is the boost cut removed?
Also is the boost cut gradual or is it rather severe? (Thinking of tweaking my 600 at the weekend you see )
E_T_V is offline   Reply With Quote Quick reply to this message
Old 19-05-2006, 14:24   #5
Rover_ron
The ecu cuts the fuel SUDDENLY at about 21psi - there's no mistaking it!!.
Standard setting is 1bar -15psi.
The Tu1's boost maximiser will stop the ecu detecting high boost pressures.
Ron
Old 19-05-2006, 14:36   #6
E_T_V
Many thanks for the info.
Rover 45 2.0 TD engine type question palnie_ro MG ZS / Rover 45 & 400 3 18-01-2008 19:50
rover 45 td braineebird MG ZS / Rover 45 & 400 9 31-07-2007 16:51
rover 45 td ash-uk1 MG ZS / Rover 45 & 400 2 29-04-2007 11:03
Rover 220 Turbo Coupe - 1995 - Packet (Uneven) TURBO Boost RichMann Coupe 8 19-11-2006 13:15
Rover 45 - power boost 75TF MG ZS / Rover 45 & 400 0 27-06-2005 12:42
