75 2.0 Turbo diesel ECU failure - Page 2 - MG-Rover.org Forums
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 22-07-2007, 22:29   #21
morris-mg
Car: Rover 75 tourer 2.5 auto. Chromactive Spectre.
Originally Posted by motoroller View Post
I've got some problems which I put in another thread. The car cranks but does not start. It was working fine, but after going through a couple of small(ish) puddles, it will not start. Got it back home, and it started once. It doesn't start again. I think it may be the ECU. Where is the ECU located?
In the plenum chamber below the wipers.
morris-mg is offline   Reply With Quote Quick reply to this message
Old 23-07-2007, 21:43   #22
TBrice
Car: Rover 75
re ply to ECU problem
Go to the ECU doctor. Plympton Plymouth
Very good service cost me 180 Two attempts Now working perfect with a 12 month guarantee,
TBrice is offline   Reply With Quote Quick reply to this message
Old 31-07-2007, 19:23   #23
motoroller
Car: Rover 75
I've sourced a replacement - are the ECUs locked to certain cars? Or can they be swapped? I've ordered the ECU at 99 + delivery etc. - seemed too good! What about the white box next to the ECU?
motoroller is offline   Reply With Quote Quick reply to this message
Old 01-08-2007, 20:54   #24
Keith Alexander
Car: ZT 400 and a T4
Engine ECU must be brand new if you can't get yours repaired you can not fit a second hand one
It must be coded on Testbook to the car
The little White box if yours is a diesel is the Glow plug relay well worth taking the top off to see what state the contacts are in
Keith Alexander is offline   Reply With Quote Quick reply to this message
Old 01-08-2007, 21:24   #25
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
There was a brand new diesel ECU on ebay, didn't sell, starting bod 100!!!
Brand New, boxed. Bargain.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=001
Dr Dave is offline   Reply With Quote Quick reply to this message
Old 02-08-2007, 12:57   #26
kgriffit
Car: Rover 75 Tourer CDT
Hi,
I have a post here from yesterday, " Rover 75 diesel, Died".
I've just had the diagnosis from DTM in Bristol. The ECU has failed. There was water on it too, though not that much according to the RAC man who looked at it and tried to dry it out.
Apparently it's going to cost me 230+VAT to fix/refurbish.
Regards,
Kalvyn
kgriffit is offline   Reply With Quote Quick reply to this message
Old 07-08-2007, 19:21   #27
motoroller
Car: Rover 75
I've tried a working used ecu and it doesn't work. I think it's the white glow plug relay box... anyone? Does anyone have the circuit diagram for this part? It's labelled PA-GF30.
Old 08-08-2007, 08:03   #28
MGOracle
Car: BMW E60 530d
It's not likely to be the glow plug relay as this has no bearing on starting the car.
The ECU MUST be new or it will not work. The security chip is located in the drivers footwell and this must be matched to the ECU or the same problem will appear.
Get a new ECU and it can be programmed to the EWS (security) chip and all will be well.
Even matching a used ECU with its EWS chip is still likely to cause problems so imo, bite the bullet and find yourself a new ECU and get your dealer to programme it.
MGOracle is offline   Reply With Quote Quick reply to this message
Old 08-08-2007, 09:19   #29
Keith Alexander
I agree with Mark in warm weather Glow plug heating really should not be needed to start the car it might churn over a couple of seconds longer but should start so I doubt if the glow plug relay is the cause
They do however disintegrate, pop the plastic top off and if the contacts are shot replace it anyway either with a good secondhand one or new
You may find the new ones although a direct fit are bigger and appear to have two extra contacts as they are also used on the 6 cylinder BMW engines
(I think Andrewmsteve told me that when he gave me his old one)
Old 08-08-2007, 15:04   #30
andrewmsteve
Question ecu
HI you say that you fitted a working ecu it wont work as it is not from this car only a new one can be used and programed for your car buy a new one from ebay and get it on a T 4 to set it up
andrewmsteve is offline   Reply With Quote Quick reply to this message
Old 08-08-2007, 15:24   #31
Keith Alexander
Hi Andrew are you still well?
Is the new IPK I set up behaving itself?
Old 20-01-2008, 10:08   #32
thames 300e
Car: MG ZTT
can i buy one off ebay and get it set up for my car
and what sort of cost would it be??
thames 300e is offline   Reply With Quote Quick reply to this message
Old 20-01-2008, 11:14   #33
kelvin
Car: ZT-T CDTI, MGB and OH's ZT-T CDTI..
* sigh *
http://forums.mg-rover.org/showthread.php?t=228026
kelvin is offline   Reply With Quote Quick reply to this message
rover 75 diesel water in ecu jimmyono1 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 28-10-2008 15:48
Head Gasket Failure Rover 75 Diesel? Tazfiend MG ZT / Rover 75 (Sponsored by Rimmer Bros) 7 09-06-2008 21:49
Rover 75 Diesel ECU DDE4.0 Ebay Dr Dave MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 23-07-2007 18:37
75 Diesel reverse light and parking aid failure Dickie MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 30-08-2005 21:11
Rover 75 turbo diesel upgrade jl35 MG/R Modification & Tuning 6 20-07-2005 15:24
