Rover 75 Glovebox Fusebox? - MG-Rover.org Forums
Old 13-09-2007, 17:20   #1
PeteV6
Car: MG ZTT
Question Rover 75 Glovebox Fusebox?
Hi,
Does anyone have a map/diagram of the fuses in the fusebox under the glovebox.
The other day the RAC came out to help with a flat battery - the cause of which turned out to be a fuse in this box. He removed it for the timebeing to prevent the car battery going flat. I now want to replace it to see if the problem still exists. However, there are several open slots in the fusebox - and I`m not sure which one to return it to.
its Fuse number 15 - controls the radio/satnav/aircon controls...
Cheers,
Pete
PeteV6 is offline   Reply With Quote
Old 13-09-2007, 17:39   #2
7DAVID5
Car: Rover 75 2.5 V6 Auto 2000
There should be a diagram on the cover that fits over/under the fuse box.
7DAVID5 is offline   Reply With Quote
Old 13-09-2007, 17:59   #3
PeteV6
Car: MG ZTT
Yup- found the schematic on the back of the fusebox compartment - thanks!
However - the numbered fuses on this schematic do not seem to correctly correspond to the fuses in the box. For instnace there are several 'Number 15' fuses in the fusebox!
Oh well - might be best left to the experts at the garage methinks....
Old 13-09-2007, 18:10   #4
Phil
Car: MG ZT 135+ (Plus Pack) Suzuki SV650
Sure its not 15 amp your looking at? These will be stamped on the top of each blade fuse. The number 15 you speak of, is the number 15 fuse socket, and I can tell you there is only one of these.
Phil is offline   Reply With Quote
Old 13-09-2007, 19:23   #5
PeteV6
Car: MG ZTT
Smile
Ah, ha, penny has dropped!! I`m sure your right - its a 15a fuse, Doh!
I'll take another look in the morning!
Cheers....
Old 14-09-2007, 07:56   #6
darko1429
Car: Rover 75
best to get a manual for the car it shows you all the fuses and their location
darko1429 is offline   Reply With Quote
You may not post replies
Rover 75 Fusebox and Owners manual confusion! MattL MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 18-01-2010 21:58
MG-Rover ZS Fusebox stroller01 MG ZS / Rover 45 & 400 1 12-01-2008 12:15
Rover 25 Fusebox details Sconetone MG ZR / Rover 25, 200 & Streetwise 7 10-08-2006 18:10
[rover 800] - Fuse G in the motor fusebox Rover820i Rover 800 0 29-05-2005 15:35
75/ZT - CD Changer in the Glovebox lctorana MG ZT / Rover 75 (Sponsored by Rimmer Bros) 12 01-06-2002 09:04
