smoking from cold - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 22-11-2008, 19:45   #1
cossiedave
Car: Rover 25
smoking from cold
hi peeps i am new on here s i would like to say hello first before i start asking for techy help lol,
i have a 53 plate rover 25 diesel, on start up when cold it diesel smokes for about 200 yards up the road then clears and runs perfect all day , i though it might be a leaking injector so i got another 4 and its made no difference appart from it seem to be putting more fuel in than before, i plugged a snap on code reader on it and it came up with 2 faults
code p1218 needle motion sensor and p1402 undocumented code
please help and thanks in advance
cossiedave is offline   Reply With Quote Quick reply to this message
Old 22-11-2008, 20:30   #2
Chrisund123
Car: 45 2.0 Diesel
Needle motion sensor? Think that might be the lift sensor on #1 injector, check it's plugged in and the wiring isn't chafed, tends to be a common problem.
What type of injectors did you put in? injectors out of a 25/45? or out of a 200/400/600? they are different, the earlier injectors will flow more fuel in a 25.
Chrisund123 is offline   Reply With Quote Quick reply to this message
Old 22-11-2008, 20:46   #3
cossiedave
Car: Rover 25
hi and thanks for the quick reply, the injectors i fitted were told they came out of a 45 but its goes a lot better and black smokes when on full throttle, is there any way to knock the fueling back a little
Old 22-11-2008, 21:05   #4
Chrisund123
Car: 45 2.0 Diesel
Not without a remap I'm afriad! You can always try and increase the air going in a bit by increasing the boost pressure though, which can even things up.
Old 23-11-2008, 18:19   #5
T.Morris
Car: MG ZR+
when you say it diesel smokes. What colour. is it running on all for cylinders when cold. the needle lift fault probably as just come up coz uv changed the injectors.
T.Morris is offline   Reply With Quote Quick reply to this message
Old 23-11-2008, 20:21   #6
cossiedave
Car: Rover 25
its white/grey mate and it misses on a cylinder when you start it and then runs fine after a couple off revs , some one said it may have a bent conrod but it runs great as soon as it starts to warm up
Old 23-11-2008, 21:38   #7
SDI_Tim
Car: MG ZS+ TD135+
Your 45 injectors sound like they've seen better days, they should be exactly the same as 25 ones. If you've put the older SDi type injectors in though this would explain the power and the smoke.
If they are definitely 45 injectors, it could be that they're quite worn, so I would expect some smoke for a while on a cold engine.
It could be a glow plug issue that's causing the poor combustion on a cold start.
SDI_Tim is offline   Reply With Quote Quick reply to this message
Old 24-11-2008, 16:57   #8
cossiedave
Car: Rover 25
thanks for the replys and i will take it to work tomorrow and check wires nd lso check heater plugs
Old 24-11-2008, 18:12   #9
T.Morris
Car: MG ZR+
soz but it does sound like i bent rod to me to. av you or any1 bin through any water. best do a compression test.
they are the symptoms for a bent rod sorry to say.
Old 24-11-2008, 20:57   #10
SDI_Tim
Car: MG ZS+ TD135+
Wouldn't a bent rod cause poor running for more than 200 yards, and maybe some roughness in the engine? I'm no engine mechanical expert, just curious.
Old 24-11-2008, 21:17   #11
cossiedave
Car: Rover 25
if the rod has i slight twist in it i may be down on compression untill it warms up a little but i was hoping it was some thing eisier to fix
Smoking Graham E Diesel Forum! 10 14-06-2007 11:11
Smoking? Simon Widdop Others 10 20-11-2003 18:18
