rear brakes binding, - MG-Rover.org Forums
Old 15-09-2009, 21:15   #1
bigdogrepo
Car: MG ZS
Exclamation rear brakes binding,
Rear caliper binding on. I will replace tomorrow, what causes the caliper to jam up ? fitted new discs 12 weeks ago and caliper fine then. Any ideas,
wheel heating up due to caliper jaming up can the heat have warped the disc ??
bigdogrepo is offline   Reply With Quote Quick reply to this message
Old 15-09-2009, 22:08   #2
crazyman
Car: Rover 400 (95-99)
Smile Rear caliper
I had the same prob so did my mate its the sliders on the Rear calipes
take them out clean them and grease them up and then just rebuild
them back up mate hope this helps you
crazyman is offline   Reply With Quote Quick reply to this message
Old 16-09-2009, 14:05   #3
VespaV6
Car: VW Passat 2.0 TDi 140 Highline
It will be the slidepins as said. Pushing everything back when you did the disc change will have upset the gunge and made them stick. About 40 mins work with some cleaner and coppaslip will fix it.
VespaV6 is offline   Reply With Quote Quick reply to this message
Brakes Binding daviddenise24 MG ZS / Rover 45 & 400 0 26-01-2009 13:12
Rear brakes binding. gtstaruk MG ZS / Rover 45 & 400 5 06-01-2008 21:09
Binding brakes I believe!! stevesrover200 MG ZR / Rover 25, 200 & Streetwise 4 26-05-2007 22:02
Rear brakes binding DaveVVC Coupe 6 14-02-2007 16:56
111 rear brakes binding tomk Metro / Rover 100 1 08-03-2006 18:16
