Rover 214 wont start - MG-Rover.org Forums
Old 17-11-2009, 13:17   #1
bluerover214
Hi,
I have a Rover 214, 1997. Basically it wont start. I've changed the fuel filter, spark plugs, ht leads, crank sensor and nothing makes any difference. it varies from not starting at all to starting then cutting out after a few seconds. I've had 3 different people look at it. one suggested the ecu, we got a second hand one but made no difference. someone from the garage said a new ecu is no good unless you have immobiliser box and key fob to match.
They have suggested getting an auto elecy to try and bypass the immoboliser. any suggestions?
i live in the middle of nowhere and not having a car is a nightmare! thanks
bluerover214 is offline   Reply With Quote Quick reply to this message
Old 17-11-2009, 15:03   #2
misterreliable
Car: 2004 MG ZR 120+
Originally Posted by bluerover214 View Post
Hi,
Try giving the fuel cut off button a jab!.
misterreliable is offline   Reply With Quote Quick reply to this message
Old 17-11-2009, 23:00   #3
BIGGUNS
Car: FJ1100 STREET FIGHTER
inertia switch
BIGGUNS is offline   Reply With Quote Quick reply to this message
Old 15-12-2009, 03:11   #4
philomena
hi all i need help with my gals car...
she broke the fob trying to change the battery, and i need the car tomorrow midday...
i have looked around and found bits and pieces of info on this... like a relay, and the key in the door if u have the code etc...
i have a new fob coming from ebay in 2-3 days, but the immobilser is stuck on, so according to everything i have read, i cant add a new fob until the immobilser is off...
how do i deactivate the emmobilser when i dont have the emergency code(i got the car for her for 100 with a broken gearbox, its a cheap run around) so dont really have any intention on spending loads of cash for reprogramming and sending off ecu's etc...
its a R reg 214i 5dr hatch... and time is a big problem, i need to get to work tomor 100miles away(and my car is awaiting a new starter, not a very lucky week so far...lol)...
hope this email makes sense, im a bit wired after spending the last 6 hrs reading everything about this silly alarm system rover have...
i also seen that no1 will say over a fourm how to sort this with the relay so please PM me...
philomena is offline   Reply With Quote Quick reply to this message
Old 15-12-2009, 08:22   #5
Dean Carr
Car: MR2 Roadster 2002
Send a message via MSN to Dean Carr
The ECU and immobilizer are tied together, you cannot start the car without a correctly functioning fob to disable it.
Even if you do buy a new fob, it still needs reprogramming to match your cars immobilizer.
The key code only allows you to turn off the alarm and enter the car, not start it up.
Dean Carr is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
rover 214, wont start - help please snyper MG ZR / Rover 25, 200 & Streetwise 13 13-07-2008 08:42
help needed my rover 214 wont start lee_m_25 MG ZR / Rover 25, 200 & Streetwise 20 28-03-2008 19:47
Rover 214 Help.. wont start bbmenswear Others 2 16-02-2008 15:42
Rover 214 wont start after being sat Rover_King MG ZR / Rover 25, 200 & Streetwise 2 20-09-2007 23:24
Rover 214 SEi - Wont start blinkinink 'R8' Rovers (aka Wedges!!) 1 13-11-2006 15:57
