Relay location??? - MG-Rover.org Forums
Old 02-05-2010, 14:27   #1
Benfinlayson
Car: MGF
Relay location???
I cant find where to put the relay for the heated rear window? Got the switch in fine just cant find the relay holder. I have looked all round behind the fuse box.
Any pointers?
Did it on my last F but that was good few years ago and I have slept since then!
Benfinlayson is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 14:37   #2
Will Hay
Car: I have 186 different cars
Sorry dude are you asking where in the car it should be fitted?
Mine [TF] was positioned under the steering wheel, to the right as looking at the windscreen.
Will Hay is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 14:41   #3
spaceoctagon
Car: MGTF 160
I just stuck my hand up behind the fuse box and found it, typically it already had a relay in it!
spaceoctagon is online now   Reply With Quote Quick reply to this message
Old 02-05-2010, 14:41   #4
Benfinlayson
Car: MGF
I know where it should be (sorry should have been clearer on that) I just cant find it!
Old 02-05-2010, 14:44   #5
spaceoctagon
Car: MGTF 160
should be beind there somewhere hanging loose? Unless its tapped to the loom somewhere!
Old 02-05-2010, 15:21   #6
Benfinlayson
Car: MGF
Found it!!
All done, it was tucked right up high behind the support bar. Anyway all done and switch is now illuminating when I press it.
Ta for the responses
MGTF Horn relay location aton MGF and MGTF (Sponsored by MGFnTFBITZ) 8 04-10-2009 22:19
ROVER 45 fan relay/aircon relay location moosecake MG ZS / Rover 45 & 400 3 27-03-2009 22:48
Fuel Pump Relay Location 1960darrenh MG ZR / Rover 25, 200 & Streetwise 1 11-11-2008 18:39
Horn Relay Location 600 mac600 Rover 600 1 24-02-2008 15:01
Heater Motor Relay Location Barzey MG ZS / Rover 45 & 400 1 04-02-2008 21:08
