Rover 45-Timing belt replacement. - MG-Rover.org Forums
Old 20-09-2010, 10:06   #1
mojo49
Car: City Rover
Unhappy Rover 45-Timing belt replacement.
Hi all. I want to change the timing belt on my rover 45/1.6cc ohc (02 reg). according to the haynes workshop manual, there is a metal plate opposite the starter motor, that allows access to the flywheel, enabling me to "chock" the flywheel, so I can undo & remove the crankshaft pulley, thus removing the timing belt. I am having trouble locating this metal plate, so would appreciate any & all help from the forum, please. Thank you.
mojo49 is offline   Reply With Quote Quick reply to this message
Old 20-09-2010, 10:36   #2
1955diesel
Never forgotten
Car: Other Manufacturer. Previously - more Rovers than I care to remember.
I think it depends on the model/gearbox, but if you don't have a cover plate opposite the starter motor, just take the motor itself off to access the flywheel. An alternative is to put it into top gear and then stand on the brakes or stop the hubs from turning by some other means.
1955diesel is offline   Reply With Quote Quick reply to this message
Old 20-09-2010, 10:57   #3
Captain Slow
Car: S1 Elise 111S/Streetwise VVC
Look at the sump, then cast your gaze along towards the gearbox. If I remember correctly it's on the sump side of the gearbox (it's been a few months since I did mine).
I didn't remove the cover or lock the flywheel-but then again I had the fortune of being equipped with an air gun so the likelihood of the crank jumping teeth when the bolt was undone was less.
Captain Slow is offline   Reply With Quote Quick reply to this message
Old 20-09-2010, 18:40   #4
mojo49
Car: City Rover
Talking Timing belt-flywheel cover/plate.
Hi. Thank you for the info. Much appreciated & a great help. Thanks again.
Regards
Mojo
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Which cam/pump timing belt kits do i need for my 2001 Rover 45 2.0 TD? langadeb Diesel Forum! 7 27-10-2008 13:15
Which cam/pump timing belt kits do i need for my 2001 Rover 45 2.0 TD? langadeb MG ZS / Rover 45 & 400 3 27-10-2008 10:52
Timing Belt replacement on Rover 75 mobfromcork MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 02-07-2008 12:01
Rover 45 1.6 TIMING BELT QUESTION lovemeroverido MG ZS / Rover 45 & 400 1 17-02-2007 16:01
Rover 420D Turbo - S Reg - Timing belt replacement intervals bilbo.s MG ZS / Rover 45 & 400 2 14-11-2006 20:10
