Immobiliser Fault?? - Forums
Go Back Forums > Model Specific Forums > MG ZR / Rover 25, 200 & Streetwise
Old 27-11-2010, 19:30   #1
Car: Rover 25
Immobiliser Fault??
Evening Gents.
I have a problem with starting my 25 Diesel.
Today I got a spare key cut (new fob to be ordered when I have the cash)
I went to test it and obviously it would start the engine because the old fob was in my pocket, I briefly held it near the key in order to start it and it started ok. Drove back from the shops no problem.
Later on when I went to start the car, I notice that the red immobiliser LED on the dash was not lit. Tried starting the car with no luck, all the lights come on, glow plugs warm up but it doesn't spin over.
When I tried to pull the ECU plug out then back in, the red LED light comes on and I can start the car. But next time I stop, it wont start again.
Any suggestions?
I am thinking I may have confused the car when I pulled the fob away from the steering wheel the first time...
Kehaar is offline   Reply With Quote Quick reply to this message
Old 27-11-2010, 20:13   #2
Car: NOW HAVE A 25, 45 & 75
Apart from locking and unlocking if you have remote locking and turning the immobiliser on and off the fob does not even have to be in the car for the car to run. Check the cars earth connections etc, connections on starter motor, etc.
LORDPSK is offline   Reply With Quote Quick reply to this message
Old 28-11-2010, 11:04   #3
Car: Rover 25
It looks more like the Immobiliser itself is at fault because the red LED on the dash doesn't light up except when I pull the ECU and re plug it in...
Old 28-11-2010, 14:47   #4
technozen's Avatar
Car: 200vi & Freelander XEDi
Are you pulling the plug from the engine ECU or Alarm ECU?
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - discount for .org Supporters - PM for details.
technozen is offline   Reply With Quote Quick reply to this message
Old 28-11-2010, 14:52   #5
01379 669375
Car: Vauxhall ASTRA GTC VXR
Eka code
If You require the eka code for your vehicle we can get this via the chassis number and this over rides the immobiliser so the car will start.
Trusted UK Supplier Of MG Rover Codes
MG-ROVER-CODES is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the Forums forums, you must first register.
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Date of Birth
Month Day Year
immobiliser fault big_fact_hunt MG ZS / Rover 45 & 400 12 08-02-2010 16:53
Alarm / Immobiliser Fault DOOD MG ZS / Rover 45 & 400 5 26-10-2009 14:19
strange immobiliser fault danmgzr105 MG ZR / Rover 25, 200 & Streetwise 8 20-03-2009 17:20
Rover 100 Immobiliser Fault Grizz Metro / Rover 100 2 11-01-2009 15:34
Electrical Fault - Immobiliser? SammyP MG ZR / Rover 25, 200 & Streetwise 2 17-10-2008 22:33
