CAMSHAFT TIMING MARKS Rover 200 1.4 k16 - MG-Rover.org Forums
Old 19-10-2005, 11:34   #1
john-206
Car: Rover 75
All the pictures i see appear to show the 4 marks on the camshafts in a straight line, however when I position my left sprocket Inlet mark next to my right sprocket exhaust mark (both exhaust marks pointing to back of car) aligned with the mark on the rear timing cover the four marks are not in a straight line. Should they be?
John
john-206 is offline   Reply With Quote
Old 19-10-2005, 12:17   #2
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
John - welcome..
This thread http://forums.mg-rover.org/showthread.php?t=87730 might help....
Dr Dave is offline   Reply With Quote
Old 19-10-2005, 12:35   #3
john-206
Car: Rover 75
Hi Major
Thanx 4 that but I have already viewed your pictures and threads but my question still remains unanswered.
If I put a straight edge across the camshaft timing marks would all 4 marks (2 exhaust & 2 inlet) be in a straight line when the camshafts are in the correct timing positions?
I ask this because when I try to align mine with the mark on the rear timing case cover the 4 marks are not in a straight line.
John
Old 19-10-2005, 14:41   #4
1955diesel
Never forgotten
Car: Other Manufacturer. Previously - more Rovers than I care to remember.
No, its just the marks nearest each other you should be interested in. Inlet on inlet cam, exhaust on exhaust cam. These should form a line with the cam centres. Forget the outboard marks.
1955diesel is offline   Reply With Quote
Old 19-10-2005, 14:49   #5
john-206
Car: Rover 75
Thanx 4 that 1955Diesel, Ive got those 2 lined up and the crank at the 90 degrees before top dead centre, but the engine sounds very tappety. It was dead quiet before the belt was removed.Any ideas?
John
Old 19-10-2005, 15:43   #6
1955diesel
Never forgotten
You have probably got some air in the tappets. It will clear if you use moderate revs (not too slow) but it can take 10 minutes or so.
Old 19-10-2005, 16:21   #7
john-206
Car: Rover 75
Cheers 1955diesel I'll try that. Just rechecked the timing and its spot on but the belt does seem slack as though its trying to jump a notch. I'm not sure if the tensioners working correctly and haynes doesn't show it in any detail.
John
Old 19-10-2005, 17:08   #8
1955diesel
Never forgotten
Not sure what the manual says, but I always turn the engine in order to take all the slack out of the drive side of the belt run, then recheck the timing and retension the belt.
Old 19-10-2005, 17:11   #9
Dr Dave
Administrator
Dr Dave's Avatar
I sometimes give the tensioner a helping hand to take up the tension to an acceptable level - it never seems tight enough with the spring.
Old 19-10-2005, 17:12   #10
Dr Dave
Administrator
Dr Dave's Avatar
John
Has the engine been standing for any length of time?
Old 19-10-2005, 17:13   #11
misterreliable
Car: 2004 MG ZR 120+
As mentioned turn engine manually with socket on crank bolt several times to settle in belt, so to speak, then tension it.
misterreliable is offline   Reply With Quote
Old 19-10-2005, 17:24   #12
john-206
Car: Rover 75
No engine not stood. Changed water pump couple of days back without probs then had prob getting the cambelt back on properly. Sure timing marks r ok and prob lies with tensioner (auto) I've bin slackening it off to get the belt on and dont think its workin right now.
John
Old 19-10-2005, 17:28   #13
john-206
Car: Rover 75
Thanx Ken. Can actually see the belt going slack and trying to jump a notch when I turn the engine by hand. Its an auto tensioner. Timing marks spot on.
Old 19-10-2005, 17:44   #14
Dr Dave
Administrator
Dr Dave's Avatar
I don't think you're tensioning the belt correctly....
You may not post replies
K16 engine timing marks - a definate guide! Dr Dave How Do I - Answers To Common Problems. 64 13-01-2013 20:42
K16 engine timing marks - a definite guide! Dr Dave How Do I - Answers To Common Problems. 106 24-04-2012 11:05
k16 camshaft timing marks..... Rover_King MG ZR / Rover 25, 200 & Streetwise 21 03-10-2008 22:31
K16 engine timing marks - a definate guide! Dr Dave MG ZS / Rover 45 & 400 43 03-07-2006 12:03
